v2.27.1.0 Cluster connections disconnect randomly
W1BKW
Post by W1BKW »
I have reported this in the Facebook forum with very little feedback. One other person acknowledged similar problems (but using different clusters). I normally use GB7MBC and VE2HEW-5. Never had any disconnects under 2.26. I have tried each cluster individually, same problem. I tried VE7CC, same problem.
1. Settings, Program Config, Cluster you can specify the port, but if you have multiple clusters selected in the Telnet connections does the Settings field matter? (I have tried matching it to one of the clusters, or leave it at default of 23. Neither seemed to make a difference with this issue, or ability to connect).
2. If I want to rollback to 2.26, is it as simple as creating a shortcut to the 2.26 exe file still in my folder?
Thanks in advance,
Brian, W1BKW
Re: v2.27.1.0 Cluster connections disconnect randomly
W1BKW wrote: 26 Apr 2023, 10:25
Yes the port settings matter you must use the one relevent to the cluster provider
No and you would be ill advised to reinstall the older version
When you have issues set 'Trace made' in the help menu then when the problem next occurs check the log file from the help menu and you should see the error - Note it you restart Log4OM trace mode is forgotten and needs to be re-enabled
W1BKW
Post by W1BKW »
Thank you Terry. If the Settings Port matters.... I normally have two clusters selected: GB7MBC (8000) and VE2HEW-5 (7300). How do you handle multiple clusters with different ports since there is only one field in Settings? it use to be defaulted to 23, and using v2.26 I just selected the two clusters, made one primary and they worked without issue. Never had any disconnects.
I have tried one cluster at a time and using the Settings port accordingly and it still disconnects randomly.
I will turn the trace on but I would like to know how it is supposed to be configured when using 2 or more clusters.
W1BKW
Post by W1BKW »
Terry, where do I send the log file? There was no email provided through the Prepare Support request and even an edited and zipped text file that I created is too large as an attachment here.
Please advise.
W1BKW wrote: 27 Apr 2023, 01:39 Terry, where do I send the log file? There was no email provided through the Prepare Support request and even an edited and zipped text file that I created is too large as an attachment here.
Please advise.
I did not say send the log file anywhere just read it and look for errors related to cluster
W1BKW
Post by W1BKW »
23:09 was the last update from the cluster server
Here is the next cluster related activity. Looks like it reinitialized?? I noticed the last update was old at @23:32, sent a Show Announce/Show Configuration and it disconnected completely.
2023-04-26 23:30:25.4405 DEBUG: [FwFile][ComposeFilename] : ComposeUserFilename: Returning USER file C:\Users\brian\AppData\Roaming\Log4OM2\user\layout_datagrid_cluster_Main_user.json
2023-04-26 23:30:25.4415 DEBUG: [FwFile][JsonDeserializeObject] : Deserializing C:\Users\brian\AppData\Roaming\Log4OM2\user\layout_datagrid_cluster_Main_user.json as L4ONG.BE.LAYOUT.DataGridViewStructure
2023-04-26 23:30:25.4415 DEBUG: [FwFile][LoadFile] : Begin load text file C:\Users\brian\AppData\Roaming\Log4OM2\user\layout_datagrid_cluster_Main_user.json
2023-04-26 23:30:25.4425 DEBUG: [FwFile][LoadFile] : Text file load completed C:\Users\brian\AppData\Roaming\Log4OM2\user\layout_datagrid_cluster_Main_user.json
2023-04-26 23:30:25.4435 DEBUG: [FwFile][ComposeFilename] : ComposeUserFilename: Returning USER file C:\Users\brian\AppData\Roaming\Log4OM2\user\layout_cluster_Main_user.json
2023-04-26 23:30:25.4435 DEBUG: [FwFile][JsonDeserializeObject] : Deserializing C:\Users\brian\AppData\Roaming\Log4OM2\user\layout_cluster_Main_user.json as L4ONG.BE.Layout.ClusterLayout
2023-04-26 23:30:25.4435 DEBUG: [FwFile][LoadFile] : Begin load text file C:\Users\brian\AppData\Roaming\Log4OM2\user\layout_cluster_Main_user.json
2023-04-26 23:30:25.4445 DEBUG: [FwFile][LoadFile] : Text file load completed C:\Users\brian\AppData\Roaming\Log4OM2\user\layout_cluster_Main_user.json
2023-04-26 23:30:25.5289 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from KA7KDX
2023-04-26 23:30:25.5299 TRACE: [FwHam][ExtractCallsign] : KA7KDX -> KA7KDX with prefix
2023-04-26 23:30:25.5519 TRACE: [WindowPositions][GetLastLocation] : [WIN POSITION] Retrieving location for FormClusterManagement: L4ONG.Common.WindowPosition
2023-04-26 23:30:25.5581 TRACE: [L4ONGFormBase][dje_zYZ2MUHRDC55RCFKXHUNJD_ejd] : Opening L4ONGFormBase
2023-04-26 23:30:25.5581 DEBUG: [FormClusterManagement][dje_zZN77Y62WA4AE2T2_ejd] : Initializing form settings...
2023-04-26 23:30:25.5581 DEBUG: [FwFile][ComposeFilename] : ComposeUserFilename: Returning file C:\Users\brian\AppData\Roaming\Log4OM2\clustercommands.txt
2023-04-26 23:30:25.5581 DEBUG: [FwFile][LoadFileAsList] : LoadFileAsList: Begin load text file C:\Users\brian\AppData\Roaming\Log4OM2\clustercommands.txt
2023-04-26 23:30:25.5581 DEBUG: [FwFile][LoadFileAsList] : LoadFileAsList: Text file load completed C:\Users\brian\AppData\Roaming\Log4OM2\clustercommands.txt
2023-04-26 23:30:25.5581 DEBUG: [FwFile][LoadFileAsArray] : LoadFileAsArray: Text file load completed C:\Users\brian\AppData\Roaming\Log4OM2\clustercommands.txt
2023-04-26 23:30:25.5797 DEBUG: [FwFile][ComposeFilename] : ComposeUserFilename: Returning file C:\Users\brian\AppData\Roaming\Log4OM2\cluster.xml
2023-04-26 23:30:25.5797 INFO: [ClusterConfigurationLogic] : Loading default cluster list from C:\Users\brian\AppData\Roaming\Log4OM2\cluster.xml
2023-04-26 23:30:25.5797 DEBUG: [FwFile][DeserializeObject] : Deserializing C:\Users\brian\AppData\Roaming\Log4OM2\cluster.xml as L4ONG.BE.Configuration.ClusterList
2023-04-26 23:30:25.6210 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from JH7AUL
2023-04-26 23:30:25.6210 TRACE: [FwHam][ExtractCallsign] : JH7AUL -> JH7AUL with prefix
2023-04-26 23:30:25.7318 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from ZL2GBX
2023-04-26 23:30:25.7318 TRACE: [FwHam][ExtractCallsign] : ZL2GBX -> ZL2GBX with prefix
2023-04-26 23:30:25.7819 DEBUG: [FwFile][DeserializeObject] : Deserialized C:\Users\brian\AppData\Roaming\Log4OM2\cluster.xml as L4ONG.BE.Configuration.ClusterList
2023-04-26 23:30:25.7838 DEBUG: [FwFile][ComposeFilename] : ComposeUserFilename: Returning file C:\Users\brian\AppData\Roaming\Log4OM2\cluster.xml
2023-04-26 23:30:25.7838 INFO: [ClusterConfigurationLogic] : Loading user cluster list from C:\Users\brian\AppData\Roaming\Log4OM2\cluster.xml
2023-04-26 23:30:25.7849 DEBUG: [FwFile][DeserializeObject] : Deserializing C:\Users\brian\AppData\Roaming\Log4OM2\cluster.xml as L4ONG.BE.Configuration.ClusterList
2023-04-26 23:30:25.8322 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from YV1SW
2023-04-26 23:30:25.8322 TRACE: [FwHam][ExtractCallsign] : YV1SW -> YV1SW with prefix
2023-04-26 23:30:25.8947 DEBUG: [FwFile][DeserializeObject] : Deserialized C:\Users\brian\AppData\Roaming\Log4OM2\cluster.xml as L4ONG.BE.Configuration.ClusterList
2023-04-26 23:30:25.9416 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from BH4ERB
2023-04-26 23:30:25.9416 TRACE: [FwHam][ExtractCallsign] : BH4ERB -> BH4ERB with prefix
2023-04-26 23:30:26.0509 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from W9YB
2023-04-26 23:30:26.0509 TRACE: [FwHam][ExtractCallsign] : W9YB -> W9YB with prefix
2023-04-26 23:30:26.1389 INFO: [FormClusterManagement] : Cluster instance initialized
2023-04-26 23:30:26.1577 WARN: [dje_z9FB7FE4S8K7NR4TK7Z6XWE8FVWZQ_ejd][MoveNext] : BaseImage is null
2023-04-26 23:30:26.1641 TRACE: [ChatUsers][Drop] : Chat user dropped: N5JGE
2023-04-26 23:30:26.1797 TRACE: [dje_zR2AP76K8X6PEWBKBY2HPF_ejd][MoveNext] : Updating map for ClusterMap
2023-04-26 23:30:26.1797 TRACE: [dje_zR2AP76K8X6PEWBKBY2HPF_ejd][MoveNext] : map baseimage set
2023-04-26 23:30:26.1797 TRACE: [dje_zR2AP76K8X6PEWBKBY2HPF_ejd][MoveNext] : image set
2023-04-26 23:30:26.1797 TRACE: [dje_zR2AP76K8X6PEWBKBY2HPF_ejd][MoveNext] : Cluster Map drawing
2023-04-26 23:30:26.1953 TRACE: [dje_zR2AP76K8X6PEWBKBY2HPF_ejd][MoveNext] : Cluster Map drawing completed
2023-04-26 23:30:26.1953 TRACE: [dje_zR2AP76K8X6PEWBKBY2HPF_ejd][MoveNext] : Ending map update for ClusterMap
2023-04-26 23:30:26.2726 TRACE: [ChatUsers][Drop] : Chat user dropped: EA7AC
2023-04-26 23:30:26.4482 TRACE: [dje_zSVWLZB3YQ5M6KNQ35ZSVF_ejd][MoveNext] : Executing planned scheduler...
2023-04-26 23:30:26.4482 TRACE: [LogWriter][DumpProcess] : ## DUMP MODULES ##
2023-04-26 23:30:26.4482 TRACE: [LogWriter][DumpProcess] : ## DUMP ##MoveNext dje_zUAUBTBPVYZ6CVGAL587TXN9YC9HA_ejd 1
2023-04-26 23:30:26.4482 TRACE: [dje_zSVWLZB3YQ5M6KNQ35ZSVF_ejd][MoveNext] : Planned scheduler executed...
2023-04-26 23:30:26.7989 TRACE: [dje_zLHQJAQG5H7N8GGTKG3JNCZ9YDV2H9JQ759DF37WA_ejd][ParamsChange] : Rig 1 Param 880
2023-04-26 23:30:26.8143 TRACE: [OmnirigEngine][GetFrequency] : CAT OMNIRIG2 -> LOG4OM RIG1 VFO: PM_VFOAA Freq: 28493500 RX: 28493500 TX: 28493500 FreqA: 28493500 FreqB: 28465000 SPLIT: PM_SPLITOFF
2023-04-26 23:30:26.8143 TRACE: [OmnirigEngine][GetFrequency] : CAT PACKET: Omnirig Rig1 EMISSION:Undefined MODULATION: Undefined OnAir:False Split:False
VfoA Freq:28493.5 Tx:True Rx:True Valid:True
VfoB Freq:28465 Tx:False Rx:False Valid:True
No disconnect information in the part of the log file you published and no error so we cannot see the problem
W1BKW
Post by W1BKW »
Why is it reinitializing all those files, etc.? Is that where I loaded the Telnet Cluster Management window to send a command to see if it was asleep or not? Sometimes when I look it is completely disconnected, other times it is like it went to sleep. I will notice the last update time is quite old and will open the management window and send a command. Most times it will cause a disconnect.
I switched to GB7MBC for today and in trace mode. I will monitor.
Do you have 'Enable connection keep alive' checked?
W1BKW
Post by W1BKW »
Keep Alive was checked but the rest of the fields were blank so I edited the form and and saved it and reconnected on the U GB7MBC: 8000 and reconnected. Will monitor.
