- 3cm cluster.jpg (38.63 KiB) Viewed 2912 times
3cm fake news !!!
Re: 3cm fake news !!!
decimal in wrong spot, so maybe it should 5.774, which would result in being 60m. is this what you are trying to point out
Dave ve3wej / ve3ie
3cm band is 10GHz not 5GHz. No one seems to suggest a reason for this error, or a solution...
Cris,yo2oxd wrote: 29 Apr 2023, 19:09 3cm band is 10GHz not 5GHz. No one seems to suggest a reason for this error, or a solution...
Well ... you made the post and it has been noted and the developers are aware and have it on a list for review and likely repair for a future release.
What else might you want or be expecting?
Its working properly in V2.27.1.0
Fat Finger Typing can often cause things to break!!
Alan,
Tnx for the input. I've never used that band so was not sure.
I also forgot to ask Cris what version of Log4OM he is using. For sure it is not the most current release.
Another question ... what version of Log4OM are you using?
Whatever it is pls update to Beta V 2.27.1.2 (March 24, 2023)
https://www.log4om.com/download/
Sorry, i'm missing the point...
the decimal separator in some countries is "." and the thousand separator is comma ","
Other countries have this configuration inverted, so "thousand separator" is "." and decimal separator is comma ",".
In this case the user seems to have decimal separator set to "dot" and thousand separator set to "comma"...
i'm missing the problem...?
Russel,
Your login username has been changed per your signature notice on the post.
- g5art.JPG (26.88 KiB) Viewed 2687 times
The upgrading to 2.27.1. solved the problem and I can now see the 2.4GHz and 10GHz bands in cluster view. Thanks for the support.
KI5IO wrote: 30 Apr 2023, 15:42Cris,yo2oxd wrote: 29 Apr 2023, 19:09 3cm band is 10GHz not 5GHz. No one seems to suggest a reason for this error, or a solution...
