I'm trying to download my eqsl records using the qsl manager so it can fill in the received field but I keep getting the error...
receive log error: index was out of range. Must be non negative and less than the size of the collection. P (i cant read the rest of the message as the box does not allow me to resize it.)
any ideas?
EQSL index out of range error.
Re: EQSL index out of range error.
cancel that... the error is misleading. it really should read... home location not found, check location...
problem solved.
problem solved.
I'm fixing this issue right now, to avoid further problems with this kind of error
Thanks for reporting
