Since using v2.28.0.0 QRZ downloads of know verified QSO's are not updating the logbook, despite the QRZ message.
Even by adjusting the date as attached or going to the start of my log since 2018, the same message is received.
Previously the screen would show the updated QSO's that are confirmed.
Gavin
ZL3GAV
QRZ DOWNLOAD
- ZL3GAV
- Advanced Class
QRZ DOWNLOAD
- QRZ.png (27.38 KiB) Viewed 2734 times
Re: QRZ DOWNLOAD
Not absolutely shure but if i am right qrz.com don´t has a download to Log4OM like eQSL or the LotW. Also Clublog and HamQth don´t
give the possiblity to download confirmations.
- ZL3GAV
- Advanced Class
Re: QRZ DOWNLOAD
QRZ download confirmations were provided a couple of versions back, and this worked correctly until this last release as described.
- ZL3GAV
- Advanced Class
Re: QRZ DOWNLOAD
Note the functionality was available since this release, and has worked correctly until the new release, including the last beta.
Re: QRZ DOWNLOAD
Well it works fine here using 2.28.0.0, see belowZL3GAV wrote: 13 Jun 2023, 21:06 Note the functionality was available since this release, and has worked correctly until the new release, including the last beta.
Have you checked that your QRZ API Key is OK?
And the updates listed have been done in my logbook
- ZL3GAV
- Advanced Class
Re: QRZ DOWNLOAD
Hi Terry
Thanks, no issue with the API key.
I note your download showed the entire logbook sync, would be interested if it works for new QSO's?
Gavin
ZL3GAV
Gavin
ZL3GAV
Re: QRZ DOWNLOAD
ZL3GAV wrote: 14 Jun 2023, 20:28 Hi Terry
Gavin
ZL3GAV
I just checked and downloaded all QSo's from the last download (13/06/2003) and that also worked fine, a couple of new updates.
The previous one shown was not from the start of my logbook it was just from a date I chose for testing and as you can see the QSO's that had not been updated before were synchronised correctly.
Conlusion is that it is working fine for me and I dont think there are any other users having a problem so it must be local to you.
I know you said the API key was OK but it might be worth copy and pating it in again just to be certain?
- ZL3GAV
- Advanced Class
Re: QRZ DOWNLOAD
Unfortunately still not working, and updating Log4OM. The key is validated etc.
Re: QRZ DOWNLOAD
Engage debug mode in the help menu
Try another download
Then generate a support request from the help menu
Send the resulting zip file to lele (at) pisto.it
Re: QRZ DOWNLOAD
I also have issues with QRZ downloads. It start to download more then 13000 records from 2011. Just a few new ones would be nice.
I,m using V2 2.28.0.0
What do I have to change.
Roland
Roland
