I set up a new computer, installed Log4OM 2.28 and manually reconfig settings. I exported ALL log info on old computer and imported into new computer with Quality checks at #3. You can see the missing confirmations in the attached pics. The missing confirmations are also on MANY other entities not just CE0Y. Under Maintenance I ran 'Rescan QSO Reference's' and monitored via Help/Realtime log, until finished. Rebooted and same issue.
Any help would appreciated.
Dave
k4em
Missing confirmations after import
- ce0y new computer.png (7.97 KiB) Viewed 894 times
- ce0y old computer.png (7.29 KiB) Viewed 894 times
Re: Missing confirmations after import
1. Is the view filter set to worked or just confired?
2. Have you done a complete download from LOTW?
3. On import what did you nhave the 'Award check' set to?
On the new computer Log4OM I made one change. Under Settings/Confirmation; I added 'Thanks & 73' in the 'QSL default message', the pic shows it after I removed it. I deleted that message and it is now working, as you can see the CE0Y now shows all my confirmations. I also checked 10 to 15 other PFX's and all is now good.
Dave
k4em
Dave
k4em
- conf computer.png (7.88 KiB) Viewed 887 times
- conf new computer.png (13.47 KiB) Viewed 887 times
To test, I just went back into settings/confirmations, and added the Thanks & 73. It did not change anything, all pfx show up fine. Weird.
Dave
k4em
Dave
k4em
