I would like to have spots from WSJT-X appear in the Log4OM cluster just like telnet spots do. Is this possible? I don't use any intermediate programs such as JT-Alert. I can't find this addressed in the help file.
WSJT-X spots in Log4OM cluster?
Re: WSJT-X spots in Log4OM cluster?
There is not a "Log4OM Cluster". It´s only a cluster window where the spots are showing from the cluster you setted up
in the cluster settings. If WSJT-X don´t send spots to an official cluster you´ll never see any of the decoded stations in
the Log4OM cluster window except everybody is working a station and spot it.
I use a utility "SliceMaster 6000" with my Flex 6600, it has a aggregation server to aggregate spots from multiple servers and WSJT-X. I then point Log4OM to the aggregation server for spots. Works perfect, see all decodes or just CQ decodes from WSJT-X.
Ron, K9YY
Ron, K9YY
- Spots.png (24.45 KiB) Viewed 3069 times
Thanks Ron--I'm using slicemaster as well so that's exactly what I need to know.
Hello colleagues.
Excellent information from Ron about the possibility of WSJT-X sends calls as a spot to Log4OM.
In order to confirm let me ask:
I don't have Flex or any SDR, I just want to have the callsign heard locally on my WSJT-X on Log4OM, does it work?
This is an option I've long yearned for. So it seems that we have a very acceptable solution.
And now a request... if a colleague has set up to "feed" only Log4OM, it would be very helpful if it is possible to share.
73 Manuel Fernando CT1BXX
SliceMaster is a program that only works with Flex SmartSDR. So this application wont work for you.CT1BXX wrote: 14 Jul 2023, 11:18 I don't have Flex or any SDR, I just want to have the callsign heard locally on my WSJT-X on Log4OM, does it work?
Hi Rich,
Thanks for information , in fact I imagened it
Have a nice weekend.
