Change default settings for CW report
Pa0ply
Post by Pa0ply »
I ever edited this section to match reports used in EME.
However I deleted a few reports which I am in need now.
Can any-1 guide me where to edit those reports?
Thanks in advance,
Jan, PAoPLY
Re: Change default settings for CW report
Jan,
Go to: Settings / Resources Editor ... then scroll down (left column) to the rst.xml file. Click to open and you can edit and save.
It is saved as "rst_user.xml" indicating it is a modified file for use in Log4OM.
Also then the original file is still intact.
Pa0ply
Post by Pa0ply »
Nolan,
Thanks, will check this.
Br. Jan
