How to upload Lotw after importing a n adif file??
hb9gur
Post by hb9gur »
Hello to all of you,
I made te ww contest during the we, and I was using a another log software for the contest. After importing the adif in Log4OM, I was abble to upload the QRZ.com easely, but I didn't find the way to select all my 326 qso to upload them on LOTW..... I really don't understand what I'm doing wrong, but using "select required" not any of my qso are selected to upload them on Lotw. Can someone help me to find the way to do it? Because I'm not going to upload one by one!!! Thanks a lot for your help, read you soon 73 qro HB9GUR
Re: How to upload Lotw after importing a n adif file??
Is it possible that your contest program already uploaded them?
Otherwise..................................
In QSL Manager
QSL Manager.png (89.33 KiB) Viewed 3955 times
hb9gur
Post by hb9gur »
Thanks for your answer, but when I do this way, no qso appears in the window... What can I do??
My contest log doesn't send to lotw.
Tnx a lot 73 qro
hb9gur wrote: 30 Oct 2023, 08:21 Thanks for your answer, but when I do this way, no qso appears in the window... What can I do??
Tnx a lot 73 qro
You must have a filter set like 'sent' no, make sure all filters are off before selecting 'Search' not Required
ei6kw
Post by ei6kw »
Check what is in Log4OM 'LOTW_SENT' field. Depend from your settings should be e.g. "requested", but in my case after adif import from contest logger this field going to 'No' - don't know why. If it is a case, you need to change this field for imported QSOs for "requested".
__
73!
de EI6KW, Slav
[url]https://www.hamqth.com/ei6kw[/url]
hb9gur
Post by hb9gur »
Sorry have a look at the jpg inclued, if it is right, it still doesn't work..
You have NO in the sent field remove it and try again the 'SEARCH' button
Are you certain that your Contest software has not already uploaded the QSO's, Have you CHECKED?
hb9gur
Post by hb9gur »
Ok with "nothing" in set I got 2 qso that have uploaded one by one.
With "no" = no qso
with "requested" = no qso
with "queued" = no qso
with "yes" = the same 2 qso as with "nothing"
with "invalid" = no qso
Thanks for your great help
Please export an ADIF file from Log4OM and email it to me at g4pop (AT) arrl.net
Have you checked on the LOTW website to see if the QSO's were already uploaded?
