qrz confirmation downloads
ve3wej
Post by ve3wej »
tried another download today, and saw it was to go back to 2023-10-09, but it has redownloading back 14,000+ ( for what I saw), and of course they are already confirmed. why did it not start at 2023-10-08 ( last download)
Dave ve3wej / ve3ie
ZL3GAV
Re: qrz confirmation downloads
Post by ZL3GAV »
I have had the same issue since just after the first release of the QRZ download feature, irrespective of manually setting the download date in QSL Manager it does not update unless I set an historical date in 2018 when before the log started. With 46,575 QSO's it takes a while, so I let it do it's thing and come back later.
I think because I sync the download of LoTW from QRZ, QRZ must flag the records as already downloaded, just a theory....
Gavin
ZL3GAV
At this time I don't think the QRZ download apps is allowing partial downloads, hopefully they will add it soon
KJ9Z
Post by KJ9Z »
"At this time I don't think the QRZ download apps is allowing partial downloads, hopefully they will add it soon"
When I download QRZ confirmations, QSL Manager also downloads every record each time regardless of the last received date setting. Are you saying this is normal Log4OM behavior and the isssue is with QRZ.com?
73 - Jim Plahitko - KJ9Z
Indianapolis, IN
This is the format Log4OM uses for data download from QRZ.COM
https://logbook.qrz.com/api?key=[b]<YOUR API KEY>[/b];ACTION=FETCH;OPTION=STATUS:CONFIRMED;BETWEEN:2023-08-19+2023-11-19
In this call i'm fetching data from 19/08/2023 to current date, according to this page https://www.qrz.com/docs/logbook/QRZLogbookAPI.html (FETCH ACTION)
There is something wrong there, as in one part the "usage notes" reports usage of comma "," to separate fields, while in the final usage note their mention to use "&" or ";"
I've tested it now, and seems working correctly with "," instead of ";"
I'll pack a new BETA version soon to fix that
ve3wej
Post by ve3wej »
Has this been done yet???
Dave ve3wej / ve3ie
I think Lele forgot to upload the modified file but I have just reminded him to do so
KJ9Z
Post by KJ9Z »
I downloaded from QRZ today and it still downloads the complete log and not just the records since the last download.
For what it's worth, I have done some experimentation with the QRZ url. I agree the API is confusing regarding the use of ampersand and semi-colon under the Fetch Options. IMHO, I believe that statement refers to their use for separating commands in the URL and is written poorly.
At the beginning of the API, the ampersands are shown in Red separating the commands. However, I tested with both ampersands and semi-colons and the only difference was the location of the result string.
The ampersands printing in this message look like this: &
Using ampersands:
https://logbook.qrz.com/api?key=mykey&A ... :date+date
The result string "&RESULT=OK&COUNT=2" was at the end of the records.
Using semi-colons:
https://logbook.qrz.com/api?key=mykey;A ... :date+date
The result string "RESULT=OK&COUNT=2" preceded the records.
Regardless, the correct number of records were returned when I separated the STATUS and BETWEEN options with commas as you stated.
Thank you very much for looking into this.
Indianapolis, IN
ZL3GAV
Post by ZL3GAV »
Hi Jim
Interesting thread regarding the dodgy API.
With v2.30.15 beta the QRZ download does work, but with limitations. My log starts in 2018 and has some 48K QSO's. I sync LoTW to QRZ etc so that also increases the QRZ verified numbers. On the first instance of running a QRZ sync with the latest beta, it too went off and did the whole database. I left it went to the supermarket and returned an hour or so later and it was just finshing. The next day after a few more QSO's added it correctly updated only that small batch, so all was good with the world.
However, the issue is that retrospective QSO's, say last week, last year etc. now confirming in QRZ that are QSO's before the last download date are not marked as verified in LOG4OM as they are missed in the sync. The only solution to capture these is to resync the logbook from Day One of your logbook periodically.
Getting back to your point, if the API was more sophisticated it would handle this issue. Noting QRZ are advertising for a Software Engineer at the moment.
Gavin
ZL3GAV
I am using the latest Beta release https://www.log4om.com/l4ong/release/be ... 5_beta.zip and I cannot emulate your issues its working fine for me and marking the QSO's accordingly.
I have however asked Lele to check this topic and comment
See my image below
