DDFM Award PB ?
F6FLU
DDFM Award PB ?
Post by F6FLU »
Hello, something I don't understand in the DDFM award
If I look in the DDFM-07 I have "C" because I had the QSL confirmation paper
2024-01-31 10_12_54.jpg (160.91 KiB) Viewed 2522 times
If I look in the DDFM-08 I have "V" because I have validation by LOTW and not by the paper QSL
2024-01-31 09_59_27.jpg (183.46 KiB) Viewed 2522 times
But
If I look at the DDFM-09 I get “W” even though the QSO is validated by LOTW
2024-01-31 10_00_38.jpg (157.64 KiB) Viewed 2522 times
What must be done for Log4OM to take this LOTW into account?
I must probably have an error somewhere?
Thank you for your help
Dan - F6FLU
https://F6FLU.org
F6FLU
Re: DDFM Award PB ?
Post by F6FLU »
2024-01-31 10_02_37.jpg (32.28 KiB) Viewed 2521 times
2024-01-31 09_55_02.jpg (24.33 KiB) Viewed 2521 times
2024-01-31 09_54_41.jpg (40.11 KiB) Viewed 2521 times
Dan - F6FLU
https://F6FLU.org
F6FLU
Re: DDFM Award PB ?
Post by F6FLU »
for information
I have dozens of errors like this
The correction is simply to take QSO by QSO and re-create the DDFM in the "Award Refs" field.
and then everything is OK
So it's just to give the information to the developers that there is a problem, it's not serious but what is important is that Log4OM does not report an anomaly, it would be good if we could fix a utility to check this consistency :-)
Dan - F6FLU
https://F6FLU.org
Re: DDFM Award PB ?
Have you rescanned the award refs in Award statistics/maintainance?
Dis you use the Massive editor to set granted or submitted?
F6FLU
Re: DDFM Award PB ?
Post by F6FLU »
no Terry I haven't done either but I'm going to look into doing these manipulations
THANKS
Dan - F6FLU
https://F6FLU.org
OE6CLD
Re: DDFM Award PB ?
Post by OE6CLD »
Hi Daniel,
That's easy to answer. Acccording to
https://ddfm.r-e-f.org/english/english.html
- In agreement with the I.A.R.U. Region 1 rules, each claim must be accompanied by a QSO list and by a statement from the applicant's national DX-AWARD-MANAGER that correctly filled in QSL's are really in possession of the applicant. If it's not possible the applicant must submit all the QSL's concerned
There is nothing mentioned on the REF web page that LoTW contacts are valid for any REF award, therefore by default this is not enabled. If you want to customize this for you locally, you can change this in the DDFM award definition in the Award Manager. Load the DDFM award definition, go to the Confimations tab and enable LoTW. Don't forget to save the changes and the definition.
Claus
Claus, OE6CLD/DJ0DX/EI7JZ
F6FLU
Re: DDFM Award PB ?
Post by F6FLU »
Tanks Claus ...
Dan - F6FLU
https://F6FLU.org
