Call sgin lookups not working on 2.32
M0LZN
Post by M0LZN »
When i enter a call sign the lookup works and populates the users data.
I updated today to 2.32 from 2.31 and this stopped working.
I tried on my field laptop and tested it worked before I did the upgrade and it worked, then did the upgrade and it stopped working.
I tried changing it to look up from qrzcq instead of qrz but this made no difference.
Any ideas?
Many thanks
Re: Call sgin lookups not working on 2.32
M0LZN wrote: 15 Mar 2024, 12:33 Hello,
Any ideas?
Many thanks
James,
I just installed the same/latest release as you have noted and the Main UI lookups are working FB here.
Maybe try a re-installation of the new release?
M0LZN
Post by M0LZN »
Just tried that. First time a install on top and same issue.
2dn time removed log4om and removed the folder from c:\user\m0lzn\appdata\roaming\log4om and the did a fresh install .
Same issue.
It does flash up the data lookup in the call sign.
Checking the log viewer it does this:
Code: Select all
14:50:59.696 Info:          [dje_zMHKFRAFDU5792C44FYSWD_ejd] : [QRZCOM] Search start on M0LZN (originally M0LZN)
14:51:00.135 Info:        * [dje_zMHKFRAFDU5792C44FYSWD_ejd][439 ms] : [QRZCOM] Search finished on M0LZN (originally M0LZN)
14:51:00.135 Error:         [dje_zXA927ZKYSCNH7YV5PR8PC2ULM66T5Z89RS_ejd][MoveNext] : [EXCEPTION] The given key was not present in the dictionary.
Any ideas?
Many thanks
Your only a 'Ham memnber. not an XML subscriber to QRZ so you wont get the lookup
If you dont want to pay for QRZ try HamQTH which you can register for free lookups
M0LZN
Post by M0LZN »
i haven't been a xml member of QRZ for a few months so wonder why it was working on version 2.31 this morning and updating to 2.232 stopped it working.
Also qrz lookups are working in other apps .
M0LZN
Post by M0LZN »
removed 2.32 and installed 2.31 and its working fine.
pd1ajj
Post by pd1ajj »
I have the same experience with the 2.32 version. I am not a QRZ subscriber but i get the green sign when i fill in the QRZ login and password under "info providers". I am using Log4om for several years now and never had a problem with it.
I re-installed the older version and everything works fine again.
Hope this wil be fixed soon in a newer version.
thanks that could help
New version available is 2.32.1.0 please check.
pd1ajj
Post by pd1ajj »
Tried downloading the new version 2.32.1.0. on Windows 11 laptop. Windows Defender reports there's a virus detected and aborts the download.....
Windows Defender detects: Trojan:Script/Wacatac.B!ml
