cluster spots
ve3wej
cluster spots
Post by ve3wej »
is there a way to have my cluster spot call the frequency from 'cat' instead of me typing it in each time, like a check box with the option to toggle on or off??
Dave ve3wej / ve3ie
Re: cluster spots
More detailed explanation please
ve3wej
Re: cluster spots
Post by ve3wej »
from the cluster management window
where the KHZ window says zero, but could it not match the cat window, and fill in automatically. or use a toggle box to say yes to cat frequency
send spot.png (3.55 KiB) Viewed 2686 times
Dave ve3wej / ve3ie
Re: cluster spots
When you have CAT connection the frequency is automatically filled
And of course you need a call sign in the input field
wb2bin
Re: cluster spots
Post by wb2bin »
You Can click on the recent spots and it will transfer to the call sign window.
Greg
wb2bin
Re: cluster spots
Post by wb2bin »
I meant recent QSO's.
Re: cluster spots
As shown below ...
