Can the CAT window be resized, that is, made larger. I'm asking about the upper left corner area.
Thanks, Phil
can the CAT window be resized?
Re: can the CAT window be resized?
If you refer to the one in the main UI then no, however the CAT screen (Window) accessable from the connect\CAT menu can be
