windows needed to post serial #s recvd and sent
wp4jd
Post by wp4jd »
It seems I cannot open the CONTEST WINDOW, nor can I modify the data input windows to add the above information.
Can this be done thru Resource editor? Do I have to download OMNIRIG and/or CAT Interface?
Re: windows needed to post serial #s recvd and sent
Its important that you state the relese number your using, every time you post
I just checked and its working fine if you follow the user guide and set the contest settings first in the contest menu.
Once you activate contest mode the colour of the input window changes to green for contest mode and the exchange fields are displayed - We have not used a seperate contest window for ages!
