CAT control with flrig not working Raspberry Pi
GW0WZL
Post by GW0WZL »
I have flrig installed on a raspberry pi running bookworm. Also installed is wsjtx. They work great together with flrig connected to my Yaesu ftdx3000 and sending receiving data to and from wsjtx.
I have log4om on a laptop running win 10, this receives logged contacts from wsjtx on the pi no problem. I can also setup wsjtx and mshv and sstv on my laptop and all will connect to flrig on the raspberry pi without a problem. BUT I cannot get any CAT control on log4om from flrig on the pi. I have read and tried all the posts on this forum....I think. I have been trying for 2 days.
The log seems to show that log4om is trying to make the connection with hamlib and the pi is refusing it as I guess hamlib is not running, Is flrig supposed to start it?
I am trying to start the connection on port 12345 which flrig is listening to but the log shows it just trying port 4532 which is the hamlib port.??
2024-09-02 15:07:32.1903 INFO: [dje_zPCBPMEHTH9SH9NH4H6TTR_ejd] : [CAT START] by CAT usercontrol
2024-09-02 15:07:32.1910 INFO: [dje_zP76V78FDQZAS4HFJ52QLF_ejd] : [HAMLIB] Starting Hamlib service
2024-09-02 15:07:32.1910 INFO: [dje_zP76V78FDQZAS4HFJ52QLF_ejd] : [HAMLIB] Using existing connection: False
2024-09-02 15:07:32.1920 INFO: [ProgramStorage] : [CAT STATUS CHANGED] Running: True
2024-09-02 15:07:32.3463 INFO: [dje_zNBCSQG5R_ejd] : [HAMLIB] DAEMON STARTED: C:\Users\gowze\AppData\Roaming\Log4OM2\hamlib\rigctld.exe --model=4 --rig-file=192.168.1.152:12345 -vvv -Z --vfo
2024-09-02 15:07:35.3687 ERROR: [HamlibEngine][dje_zPBPHTU87HY4EFV59739YSMY2L3WA_ejd] : [EXCEPTION] No connection could be made because the target machine actively refused it 192.168.1.152:4532 System.Net.Sockets.SocketException (0x80004005): No connection could be made because the target machine actively refused it 192.168.1.152:4532
at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port)
at L4ONG.BL.CAT.HamlibEngine.dje_zPBPHTU87HY4EFV59739YSMY2L3WA_ejd()
2024-09-02 15:07:35.3697 INFO: [HamlibEngine] : [HAMLIB] Stop polling. Timeout True
2024-09-02 15:07:35.3707 INFO: [HamlibEngine] : [HAMLIB] Stopping Hamlib process...
2024-09-02 15:07:35.3707 INFO: [HamlibEngine] : [HAMLIB] Hamlib process stopped successfully
2024-09-02 15:07:35.3717 INFO: [ProgramStorage] : [CAT STATUS CHANGED] Running: False
2024-09-02 15:07:35.3747 INFO: [dje_zNBCSQG5R_ejd] : [HAMLIB] Hamlib Process exit code: -1
2024-09-02 15:07:35.3747 INFO: [dje_zNBCSQG5R_ejd] : [HAMLIB] DAEMON STOPPED. Hamlib instance terminated
GW0WZL
Re: CAT control with flrig not working
Post by GW0WZL »
Re-read everything, tried everything still not working, is it something to do with bullseye os? Other programmes will connect on my LAN through flrig flrig stable but not log40m. Help please :-)
GW0WZL
Post by GW0WZL »
Many more hours wasted, I now have log4om displaying vfo A and B frequencies, but I cannot alter them from log4om, when I hover the mouse over the freq displays it turns to a hand with finger pointing but does nothing. The display follows the radio correctly.
I got this working by issuing /usr/bin/rigctld -m 4 -s 38400 in a terminal on the raspberry pi, which I think has started hamlib rigctld connected to radio model 4 which is flrig.
Its still not working correctly if anybody can help please, but nearly there.
Re: CAT control with flrig not working Raspberry Pi
I added 'Raspberry Pi' to the topic name so hopefully it will attract more relevant attention for you.
