Seems that about half the time I open LOG4OM the configuration window opens to the Database tap.
The last saved database is listed in the SQLITE window. So I click on save and apply and the program continues as normal. Wondering why this is happening on a random basis. Perhaps I have something set up amiss?
Other than that all seems to run correctly. Any ideas? Thanks
When opening program the configuration window opens randomly
Re: When opening program the configuration window opens randomly
Where is the SQlite database stored?
On my C: drive, user folder, document folder, Log4OM folder.
The program opened up normally this morning loading the backup file just fine.
Mike - W0MS
what version number are you using?
I hesitate to download and run updated versions as the program has a tendency to save corrupted JSON files from time to time. Another random issue.
Mike - W0MS
PLease download 3.33.0.0 as this has a fix for this issue caused by Windows update
I have never known that to be the case and there have not been any other reports about such an issue, check your anti virus software is updatedW0MS wrote: 17 Oct 2024, 17:59 I hesitate to download and run updated versions as the program has a tendency to save corrupted JSON files from time to time. Another random issue.
OK thanks...
The corrupted profile JSON file issue has a solution so I'll go ahead and do the update.
Mike - W0MS
Anyone that has an issue with a new set up required on starting Log4OM or missing recent QSO's list please contact me by email if you want to test a fix version - EMAIL as QRZ de G4POP
