Version 2.34 and Dot Net 4.8
w7btm
Post by w7btm »
I installed 2.34 a week or so ago on my Windows 11 machine, but I forgot to install Dot Net 4.8.
It seems to be working fine so far. It's even connecting to JTDx and logging QSO's automatically.
Manual uploads using QSL Manager seem to work also, but I'm not sure about automatic uploads on shutdown.....
Then I wanted to install JTAlert 2.63.2, which requires .NET 6.0.
I have two questions:
1. Which features of Log4OM 2.34 require .NET 4.8?
2. Can I install both .NET 4.8 and 6.0 on the same machine without issues?
Thanks.
Re: Version 2.34 and Dot Net 4.8
w7btm wrote: 12 Nov 2024, 07:07 I installed 2.34 a week or so ago on my Windows 11 machine, but I forgot to install Dot Net 4.8.
Thanks.
1. Internal structuring so you MUST follow the instructions and use it!
2. Yes several versions of .net framework can all co-habit
VE7ATJ
Post by VE7ATJ »
Hmmmm... I already have .Net 5.0.17 and 6.0.36 installed. When I downloaded the 4.8 from MS and tried to install it, it said that the install was aborted, due to their being a higher version of .NET already installed.
Everything seems to be running OK tho...
VE7ATJ wrote: 15 Nov 2024, 16:26 Hmmmm... I already have .Net 5.0.17 and 6.0.36 installed. When I downloaded the 4.8 from MS and tried to install it, it said that the install was aborted, due to their being a higher version of .NET already installed.
Thats fairly normal
