I can no longer use filters with personal queries
For example, if I want to select the records whose
QSO date is >= 02/22/205
AND
<= 02/23/2025
AND
whose SRx field is = 10
or
Srx = 19
this does not work
QdoDate >= "22/02/2025"
AND
QsoDate <= "23/02/2025"
AND
( SRx = "10" OR SRx = "19" )
If I select the condition in the field provided in the drop-down menu and I build my query, I cannot add it using the + button at the top right
even if I do a simple query like
QsoDate >= "22/02/2025" AND QsosDate <= "23/02/2025" it doesn't work
I must probably make mistakes in these queries
Before we could create our query in the "use Params" tab and if we then went to "Use custom query" we saw the query created in "use Params" transformed and it was proposed to us in the "Use custom query" tab, we only had to put the parentheses in the right place to make a complete query
If you had any advice ...
Custom query problem
Dan - F6FLU
https://F6FLU.org
https://F6FLU.org
Re: Custom query problem
incomplete without time because the adif format includes date and time in a single field
This works fine
This works fine
YES but that doesn't works with "use custom query"
this Pb is only with "Custom Query"
if I use "Params" that works fine
Dan - F6FLU
https://F6FLU.org
https://F6FLU.org
well it works for me I just filtered 277 QSO's by date range using same parameters as your image from the 67,050 QSO's in my log
Are you sure that you had QSO's for those specific 2 days?
BTW you dont need the EXTRA 'and' because it defaults to 'And' without that
And you dont need to have the first line either it will sort all unless you add a filter for mode or band etc
YES.G4POP wrote: 01 Mar 2025, 12:19 well it works for me I just filtered 277 QSO's by date range using same parameters as your image from the 67,050 QSO's in my log
Because you use the param option and not the custom query…
Dan - F6FLU
https://F6FLU.org
https://F6FLU.org
But why use a custom query when its not required? the default parameters will do most things
Custom queries use SQL strings not the syntax your using
e.g DXCC=291 and callsign like'%1%'
This returns all US stations worked with a '1' in the call sign
Your mixing parameter strings with SQL Queries
Because I want to search that :
QSO date is >= 22/02/2025 00:01:00
AND
<= 23/02/2025 23:59:59
AND
OR
Srx = 19
OR SRX = xx etc ..
AND
AND
AND
AND
OR
Srx = 19
OR SRX = xx etc ..
AND
AND
Dan - F6FLU
https://F6FLU.org
https://F6FLU.org
Hi Dan,F6FLU wrote: 01 Mar 2025, 14:26 Because I want to search that :
AND
AND
OR
Srx = 19
OR SRX = xx etc ..
AND
AND
Please try this query
73 Manuel Fernando CT1BXX
Hello Manuel
NO that doesn't works ...
Dan - F6FLU
https://F6FLU.org
https://F6FLU.org
Hello Dan.
I am sorry that do not work.
Here I have tested and worked for me, however I want to tell you I'm not an exepert I'm just a curious person who likes to test, and in this process I've created the queries that I personally use.
Today I have family at home for lunch, but when I finish I will return to the subject and try to analyze within my small experience, however I will leave here the line of the query and suggest that you do "Copy/Paste" and try one more time.
Here is the complete text I am using: do not forget ; at end
Have a nice sunday and again sorry I have tried my best.
qsodate >= '2025-02-22' AND qsodate <= '2025-02-23' and SRx like '10';
