Awards that list counted call signs
yt9tp
Post by yt9tp »
There are number of awards that are issued for contacts with predefined list of stations.
Is it possible to support such awards in Log4OM?
Re: Awards that list counted call signs
There is an award user interface .... You can create all awards you wan´t and upload the xml file to the awards section. Then it will be supported in L4O. Or you ask for a special award and our "Award Manager" will see what he can do. For that he needs Links with the rules and callsigns to create a xml for those special awards ;) ;)
yt9tp
Post by yt9tp »
I am aware of that, actualy I did some work to create XML for WCA Award.
Thing is, that Award Manager, as far as I can see has options to use DXCC entity and date range to match QSO with award.
For awards that have list of stations that are counted for award score it would be good to have an option to list those accepted call signs.
Basically it should do if there is an option to match call sign to reference id.
Awards that use listed callsigns for points:
Brasil - World of Football
http://www.labre.org.br/wa_files/brazil ... otball.pdf
Olimpic Games in Sochi Award
http://www.srr.ru/AWARD/sochi2014_eng.php
https://sites.google.com/site/9a7pjt/ha ... ssochi2014
Part of the code is already supporting callsign, but not the user interface.
Will be done in a future release
