Two Questions - One might be easy !
GU4XEA
Post by GU4XEA »
Two questions One might be easy !
Log4OM version 2.35.1.0
1: How to enable the Greyline Map ?
2: OmniRig cat
Anyone have a 'programmers' link as to the content of the ini file that V1.2 uses ?
Double click in the cluster does not drive my Yaesu FTDX-10, i.e no frequency change, figure the culprit is in the ini file, I had some problems initially with the VFOA/B switching see viewtopic.php?p=49213#p49213 and ended up using FTDX-10 ini file from V2 omnirig. Anyhow is there information on creating the ini file contents anyplace ?
GU4XEA - Paul C
Re: Two Questions - One might be easy !
GU4XEA wrote: 26 Mar 2025, 07:41 Two questions One might be easy !
Automatic just select the map in the Program config
2: OmniRig cat
Edit in Notepad or Wordpad
GU4XEA
Post by GU4XEA »
Thanks Terry #1 was the easy one - found that.
#2 I was looking for info on the structure and specific syntax in use in the ini file and the way that it was intended to work - I don't mind writing the code but its useful to know what to put in, the ini file content isn't exactly self documenting and is somewhat cryptic.
GU4XEA - Paul
GU4XEA wrote: 26 Mar 2025, 13:15 Thanks Terry #1 was the easy one - found that.
GU4XEA - Paul
See the radio user guide for specific codes and use the test program Alex of omnirig provides, it's really easy to edit the ini file in notepad
W2KYM
Post by W2KYM »
GU4XEA - Paul
Just remember, Paul, if you're going to edit, make sure you run Notepad first as an Administrator and then select the file you wish to edit. Otherwise, it won't save. I'm pretty sure you would know :)
Jim W2KYM
