Losing CAT FT101MP
Re: Losing CAT FT101MP
And WSJT?
You did not confirm if the Omnirig version was for 2 or 4 radios
I find VPN really slows the connection and often refreshes, tried Nord and Express VPN
M0TDW
Post by M0TDW »
I don't have WSJTX running, I have with another rig sometime ago but not with this one. I did deselect the incoming UDP message from WSJTX this afternoon but Log4om still lost CAT
V1.2 of Omnirig has just Rig 1 in use only one radio connected.. Rig 2 has rig type set to none.
I normally have VE&CC's CCuser running bit it wasn't when I sent the log extract.
Bill
Have you tried it with both your firewall and ALL antivirus software turned off
I just had a thought!
You did install the genuine Yaesu com port drivers before connecting the radio to the PC didnt you? you know the standard windows drivers should not be used as detailed in the yaesu user guide.
See https://www.yaesu.com/downloadFile.cfm? ... compressed
M0TDW
Post by M0TDW »
Just tried it with anti-virus, Firewall & VPN off and it dropped out after about 6 or 7 mins.
Bill
G4POP wrote: 07 Apr 2025, 16:43 I just had a thought!
And this?
M0TDW
Post by M0TDW »
Yes I downloaded the drivers from the Yaesu website.
Bill
Well this is a mystery!
Do you have another radio you could try?
Have you got another PC to try?
Did you try a factory reset of the radio?
I think you said you had tried another USB cable?
Something odd as I have left my IC7100 running with Log4OM all day to test and not a glitch!
M0TDW
Post by M0TDW »
Yes very strange as I have said I have been using it for a good few years without a clitch.
I have used other radios without a problem
I will try another pc and get back to you maybe in a day or 2.
Thanks for input,
Bill
M0TDW
Post by M0TDW »
Morning Terry,
Tried another pc and it lost CAT. Using the same Log4om and Omnirig versions.
Maybe an issue with my radio/software config from what I have seen on the forums I think I have set up up ok.
Extracts from log file:
6 TRACE: [FwHam][ExtractCallsign] : Extracting callsign from ON4BW
2025-04-08 08:07:30.7762025-04-08 08:06:57.4081 TRACE: [ChatUsers][Drop] : Chat user dropped: K8GK
2025-04-08 08:06:59.4190 TRACE: [dje_z7RVM5NK43SU5374TE272R_ejd][MoveNext] : Executing planned scheduler...
2025-04-08 08:06:59.4200 TRACE: [LogWriter][DumpProcess] : ## DUMP MODULES ##
2025-04-08 08:06:59.4210 TRACE: [dje_z7RVM5NK43SU5374TE272R_ejd][MoveNext] : Planned scheduler executed...
2025-04-08 08:06:59.9352 DEBUG: [FwFile][JsonSerializeObjectToString] : Serializing content from L4ONG.BE.Talk.ChatMessage
2025-04-08 08:07:01.4070 INFO: [OmnirigEngine] : CAT OMNIRIG2 -> LOG4OM RIG1 IS NOT RESPONDING
2025-04-08 08:07:01.4130 INFO: [OmnirigEngine] : CAT OMNIRIG2 -> LOG4OM RIG1 IS ONLINE
2025-04-08 08:07:03.2408 TRACE: [WorkedBeforeManagement][FindWorkedBefore] : [WORKED BEFORE] Begin search for IU8LMC
2025-04-08 08:07:04.4369 TRACE: [dje_z7RVM5NK43SU5374TE272R_ejd][MoveNext] : Executing planned scheduler...
2025-04-08 08:07:04.4378 TRACE: [LogWriter][DumpProcess] : ## DUMP MODULES ##
2025-04-08 08:07:04.4398 TRACE: [dje_z7RVM5NK43SU5374TE272R_ejd][MoveNext] : Planned scheduler executed...
2025-04-08 08:07:06.4154 TRACE: [CatManagementHub][dje_zHZ7N4E5AKNWCW4SURNSCFW3AP36Q_ejd] : CAT CONNECTED: False Timeout: True
2025-04-08 08:07:06.4175 INFO: [ProgramStorage] : [CAT STATUS CHANGED] Running: False
2025-04-08 08:07:06.4264 INFO: [OmnirigEngine] : OmniRig2 Stopped successfully. Timeout: True
2025-04-08 08:12:55.3108 TRACE: [dje_z7RVM5NK43SU5374TE272R_ejd][MoveNext] : Planned scheduler executed...
2025-04-08 08:12:58.4123 INFO: [OmnirigEngine] : CAT OMNIRIG2 -> LOG4OM RIG1 IS NOT RESPONDING
2025-04-08 08:12:58.4150 INFO: [OmnirigEngine] : CAT OMNIRIG2 -> LOG4OM RIG1 IS ONLINE
2025-04-08 08:12:58.4155 TRACE: [CatManagementHub][dje_zHZ7N4E5AKNWCW4SURNSCFW3AP36Q_ejd] : CAT CONNECTED: True Timeout: False
2025-04-08 08:12:58.4155 INFO: [ProgramStorage] : [CAT STATUS CHANGED] Running: True
2025-04-08 08:12:58.4214 DEBUG: [OmnirigEngine][GetFrequency] : CAT OMNIRIG2 -> LOG4OM RIG 1 VFO: PM_VFOAA Freq: 3518430 RX: 3518430 TX: 3518430 FreqA: 3518430 FreqB: 7013100 SPLIT: PM_SPLITOFF
2025-04-08 08:12:58.4230 TRACE: [OmnirigEngine][GetFrequency] : CAT PACKET: Omnirig Rig1 EMISSION:Undefined MODULATION: Undefined OnAir:False Split:False
VfoA Freq:3518.43 Tx:True Rx:True Valid:True
VfoB Freq:7013.1 Tx:False Rx:False Valid:True
2025-04-08 08:23:46.2238 INFO: [OmnirigEngine] : CAT OMNIRIG2 -> LOG4OM RIG1 IS NOT RESPONDING
2025-04-08 08:23:46.2298 INFO: [OmnirigEngine] : CAT OMNIRIG2 -> LOG4OM RIG1 IS ONLINE
2025-04-08 08:23:51.2316 TRACE: [CatManagementHub][dje_zHZ7N4E5AKNWCW4SURNSCFW3AP36Q_ejd] : CAT CONNECTED: False Timeout: True
2025-04-08 08:23:51.2336 INFO: [ProgramStorage] : [CAT STATUS CHANGED] Running: False
2025-04-08 08:23:51.2396 INFO: [OmnirigEngine] : OmniRig2 Stopped successfully. Timeout: True
2025-04-08 08:23:52.0586 TRACE: [dje_z7RVM5NK43SU5374TE272R_ejd][MoveNext] : Executing planned scheduler...
2025-04-08 08:23:52.0606 TRACE: [LogWriter][DumpProcess] : ## DUMP MODULES ##
