I would like to suggest being able to enter a frequency in khZ in the callsign field or in the frequency field.
The up/down 1 digit concept of individual digits in the frequency display is kind of hard to use when jumping from one band to the other.
In addition a band/mode selector would be great to be able to click on a band/mode.
Frequency Entering
Re: Frequency Entering
Why when you can hover your cursor over the freq display characters and use mouse wheel to change htz, khz, mhz?
You also have a CAT control screen and direct entry in input UI
I found the CAT screen now,
thanks.
What do you mean by "direct entry in input UI"?
thanks.
without CAT you can enter the freq in the main input UI under the country and zone infodl2cc wrote: 08 Apr 2025, 16:36 I found the CAT screen now,
thanks.
