Which POTA Cluster do you use?
N4KJC
Post by N4KJC »
I have tried:
Hamalert using a filter of ,SSB, NA, and bands 10,20,40. It seems like the info stops after 5-10 minutes. I dont get disconnected and I am assuming I am hitting their 100 alerts limit. I have to disconnect and reconned to get the data flowing again. I do have keepalives enabled.
I have had better luck with pota-cluster.iz2lsc.eu port: 7373.
I really like the flexibility of the filtering in HamAlert but with the short time it is available I dont want to disconnect and reconnect every 5-10 minutes.
