Locators in logbook
M0RSF
Locators in logbook
Post by M0RSF »
Not really a problem but is there a way to log or edit locator squares as for example IO93et instead of IO93ET ?
73 Chris M0RSF
G/QRP #07737 - Fists #15922
Re: Locators in logbook
Double click the QSO in the recent QSO window to bring up the edit screen
Change the locator
Click Save & Exit
The correct format for a locator is two capital letters followed by a two digit number and ending with two lower case letters
All covered in the user guide :D
M0RSF
Post by M0RSF »
I've tried all ways but for some reason I can only use capital letters even though my CAPS light is not lit on my keyboard.
73 Chris M0RSF
M0RSF wrote:I've tried all ways but for some reason I can only use capital letters even though my CAPS light is not lit on my keyboard.
73 Chris M0RSF
So the original question should not have been "how can I edit" but rather "I can only save locators in capital letters not upper and lower case"
I will check this in a few minutes, it could be a bug
73 Chris M0RSF
OK I can report this is a bug and I will add it to our Mantis list
I think this bug has crept in with 1.18 because other entries made with 1.17 are in upper and lower case
Thanks for spotting this
checked this in my log and also logged grids in the older versions are only with big letters like IO95AA. So i don´t see an issue when testing the bata softwares. But it´s not a problem to handle grids with big letters with other software. All i testet also can handle this format. Think it´s easier to handle then using the caps for the first 2 letters and then writing the rest without the caps key ;) ;)
Why it's a "bug" to have locator all in capital letters?
I'm using some code on locator, and casing makes difference... so i uppercased it.
Is there any trouble on that, or it's only an ahestetic issue?
For me it´s not a problem .... i like it as it is and all other softwares can handle this. Think it´s only "for the eyes" :mrgreen: :mrgreen:
M0RSF
Post by M0RSF »
There are approximately another 14 new Foundation licence holders at my radio club so I plan to do another presentation on Log4OM.
In V2 would it please be possible for locators to show as IO93et instead of IO93ET please? I know its a minor to some but I am a perfectionist!
73 Chris M0RSF
i think it can be possible :)
