Hi all,
Please find attached the award definition for the HUMPS - Summitbase HuMPs Award. If you're still using Log4OM < v1.18 manually copy the attached xml file (it should be named award_HUMPS.xml) into the <user>/AppData/Roaming/LogOM/awards folder and restart Log4OM.
Starting with version 1.18.0 Log4OM will update all awards automatically, there is no need to copy the awards file to a specific folder. We really would recommend to update to this or any newer version!
More information regarding the award can be found here: http://www.summits.org.uk.
Thanks to Terry G4POP for his work!
Claus, EI7JZ/OE6CLD
Moderator: OE6CLD
Claus, OE6CLD/DJ0DX/EI7JZ
Re: HUMPS - Summitbase HuMPs Award
Claus,
I think in the first paragraph you intended to write 1.17
I think < 1.18 means every version lower than 1.18, so 1.17.x, 1.16.x, ...
Regards,
Claus, EI7JZ/OE6CLD
Regards,
Claus, EI7JZ/OE6CLD
< was on a separate line so I missed it, my apologies
