Hello.
Trying to get Comm Services working with FLDigi
I have two systems (stations+computer/QTHs). One works the other does not.
What are the two red/green indicators on the bottom of the main screen relating to Comm Services telling me?
One one station both are Green. I that it as a good thing.
On the second station, one is Yellow, the other Green and there is a red icon that when click says something about starting WCF. But I see the Log4OM Communicator is running (I see the window) and if I go to the Settings->Services it also says the WCF is not running but if I click the Start button I get a pop up dialog that says the COmmunicator is already running! I've gone through the setup a few times following the manual and making sure all the settings match my other station's settings but it is always the same problem.
Help?
Mike
Comm Service Confusion
Re: Comm Service Confusion
They should both be green if the communicator is functioning correctlyKA4CDN wrote:Hello.
This sounds like you are not running Log4om or the communicator as an administratorOn the second station, one is Yellow, the other Green and there is a red icon that when click says something about starting WCF. But I see the Log4OM Communicator is running (I see the window) and if I go to the Settings->Services it also says the WCF is not running but if I click the Start button I get a pop up dialog that says the COmmunicator is already running! I've gone through the setup a few times following the manual and making sure all the settings match my other station's settings but it is always the same problem.
Help?
Mike
