yes, sure..
I get a "Y" in the update column and if I go to Clublog I can find the QSO.
On manual, I get a "N" and cant find the QSO on Clublog.
Clublog update
Re: Clublog update
Rob
HB9ETR / G0IFL
K3/Win4K3Suite/OnmiRig/L4OM v2.33.0.0
Win10 i5-11400 @ 2.60GHz
HB9ETR / G0IFL
Re: Clublog update
I downloaded and repaired my install and now all is ok.
tnxs for inputs
tnxs for inputs
Rob
HB9ETR / G0IFL
HB9ETR / G0IFL
Re: Clublog update
Thank´s for the informaton
Re: Clublog update
The error reported is a timeout:
It seems the answer from clublog requires an higher timeout or website was busy...
Code: Select all
2014-08-23 10:27:06.6239 ERROR: *** ClubLogManagement: Upload to ClubLog caught in error ******* [Function: sendLogThread_DoWork] System.Net.WebException: [color=#FF0000]The operation has timed out[/color]at LogOM.BL.ClubLogManagement.DoSend(QSO qso, String url, String email, String callsign, String password, String apiKey)
at LogOM.BL.ClubLogManagement.sendLogThread_DoWork(Object sender, DoWorkEventArgs e)
2014-08-23 10:27:06.6289 ERROR: *** ClubLogManagement: upload caught in error with code:
Re: Clublog update
One thing I have noticed with Clublog is their update to where you can see an addition to your log on Clublog.com is very slow. I can do the right click on a log entry and add it to Clublog, with no errors, then go to Clublog and the qso is not displayed for some time. I can re-add the same qso, and the Help/Show Log report will show a dupe, but still no update in the displayed Clublog log. If I come back in several hours, the updates are displayed. So they must have a back-end which is updated immediately, but their front end which displays the log online, is slow to get the updates, which makes it challenging to troubleshoot.
Doug
W7DRM
Doug
W7DRM
Re: Clublog update
It's like what happens on LOTW, takes a while in the Q before you see it in your Recent QSOs.
