K3 mode
AB7R
K3 mode
Post by AB7R »
I notice that the mode does not always change correctly with the K3 when clicking on a spot. If I double click a spot a second time then the mode changes. Also when setting CW it changes the radio to CW-Rev.
Tnx
Greg
Greg - AB7R
Caldwell, ID
Re: K3 mode
what CAT software are you using for that? Omnirig or Hamlib?
Daniele
EA3IN
Re: K3 mode
Post by EA3IN »
Same happens here, with omnirig
Re: K3 mode
EA3IN wrote:Same happens here, with omnirig
What are you referring to when you say 'same happens here' a need to click twice or the K3 going to CW-R?
Please let me know what version of Log4OM you are using
Re: K3 mode
It's a long time since I dumped my K3 but in the back of my mind I recalled something about CW-R
I have just checked the user manual for the K3 and apparently CW-R on the K3 uses the USB and the normal CW setting uses LSB?
Although I could find no reference in the manual I did find several reference on Google about setting the default CW mode in the K3 Menu.
Perhaps we have a dedicated K3 user that can advise on this?
