You don't say if the "other software" uploaded CW QSO's to LOTW OK?w3att wrote:I have uninstalled Log4OM, and have used a different logging software for several weeks*
Invalid Mode () -Lotw
Re: Invalid Mode () -Lotw
This other software (ngenlog) does not upload directly. However, I was able to export as ADIF for Lotw and use TQSL to sign and upload with no problem.
Have you tried exporting an ADIF from Log4om and uploading it with TQSL? If so what was the result.
Yes, that works.. uploaded several times that way today (each qso seperately) pretty easy to do. I'll just do it that way from now on. Thank you very much for all the help. appreciated!
I'm so glad to use Log4OM again, it is my favorite logging program!
73 -Brian
73 -Brian
Hi Brian ...
nice to see you "back on Log4OM"
I think Terry asked you how the LotW upload works with an exported ADIF via TQSL to got more informations where we may have an issue in L4O ... or in your setup
It does not make sense to use the "old way" when we have a LotW up-/download function in Log4OM ...
On my side LotW up-/downloads with L4O working perfectly but a bit earlier when changing to ADIF 3.0 we have had little issues with SSB submodes while downloading from LotW ... I´m a "90 % CW" operator and not have had any problems to up-/download to/from the LotW but some thing should be wrong when you have problems with your CW uploads .....
Think Terry will try to check where´s a possible issue on the L4O or on your side
Sorry about my english .... is not my mothers language
w3att wrote:Yes, that works.. uploaded several times that way today (each qso seperately) pretty easy to do. I'll just do it that way from now on. Thank you very much for all the help. appreciated!
73 -Brian
Please export your complete log to an ADIF File
Then using TQSL try uploading the complete ADIF file to LOTW
Report the result here please
