In the Log4OM Home Page GUI, the minimum width of the screen is determined by the 'fixed' information F1 to F6 + ADD area. This (depending on user defined) requires some column information under the F7 and F8 tabs to be scrolled from left to right.
Can the F7/F8 area of information be allowed to overflow the Distance/LP/SP/locator by selection? This would allow some additional column information to be more easily viewed.
Thanks,
Kumar_J85K
Can the F7/F8 window information overflow the Distance info?
Re: Can the F7/F8 window information overflow the Distance i
Hi Kumar, idea is interesting, there could be an option to hide the right part of the screen, and show again on click.
It's all on panels, and bottom area share the same area to be shown...
i should check if that panel collapsing could be applicable
in the meantime, you can always move the vertical divider (between the tabbed panel section on the left, and the Distance, SP, LP, etc panel on the right), grab the divider and move it to the right, effectively hiding the right panel and expanding the left panel.
Hope that helps.
Doug - W7DRM
Hope that helps.
Doug - W7DRM
By the way... there is a small green "HIDE" text on the bottom right area... anyone tried it ?
Very true Doug, but I love my DX cluster, and Danielle is looking to incorporate the Band Select info into the immediate area.W7DRM wrote:in the meantime, you can always move the vertical divider (between the tabbed panel section on the left, and the Distance, SP, LP, etc panel on the right), grab the divider and move it to the right, effectively hiding the right panel and expanding the left panel.
Hope that helps.
Doug - W7DRM
The 'Hide' is much quicker .....
Thanks,
Kumar_J85K
