Set QSO End Time Button
ng2d
Post by ng2d »
It would be nice to have an END QSO button that stops the clock and sets the QSO end time without logging the contact. A red button to the right of the End Time, similar to the red button next to the Start Time, would be perfect. I often add comments after signing with my contact. I have to add the QSO to the log to save the current end time, then edit it in order to add comments and make any other additions or changes.
Thanks for a fine application.
- Bill - NG2D
NN7D
Re: Set QSO End Time Button
Post by NN7D »
I would also like to see this feature added in a future version. I would also take advantage of it.
Thanks Bill!
Doug
W7DRM
Start and end time manually set means you need the "manual time" flag set...
in that way you can click the red button to fix the start time and then edit the end time (with pageUp and pageDown if needed) to reflect your needs...
btw there is an undocumented feature that set the current time when you right click on the start / end time in manual time mode...
Maybe this could help
G4DWV
Post by G4DWV »
IW3HMH wrote:btw there is an undocumented feature that set the current time when you right click on the start / end time in manual time mode...
Maybe :? ? It's a fantastic feature :idea: ! Get it made official :D.
It's up to our documentation manager, Mr. Genes :)
IW3HMH wrote:It's up to our documentation manager, Mr. Genes :)
If you don't keep things secret then I can document them :D :D :D
really??? :D
ng2d
Post by ng2d »
Setting Manual time, then page up and page down sets both the start and end time together, as if the QSO lasted for zero minutes. This does not help at all thatI can see. I like to post the actual start and end time. Am I missing something?
ng2d wrote:Setting Manual time, then page up and page down sets both the start and end time together, as if the QSO lasted for zero minutes. This does not help at all thatI can see. I like to post the actual start and end time. Am I missing something?
Lets take this step by step
1. Check the manual time check box
2. Set the start time using the Page up and page down keys when you make contact with the other station
3. When you sign off with the other station right click on the end time field to set the end time
I have tested this works a minute ago and it works fine
have tested this many times when i have had ragchew contacts in CW. If a station comes back on my CQ or i come back on another ones CQ i check the "Manual Time" Box and the actual time will be frozen as start time. If the QSO ends i check the end time box and log the contact. It´s also possible to change frozen start time with the up-/dwn arrows.
That works very well for me :D :D
