eQSL Pictures
Re: eQSL Pictures
I perfectly understood your request but my intention is to keep it simple.
We have users that keeps Log4Om database syncronized on dropbox. Usually when you shut down the station you will also turn the PC off in a couple of minutes or less.
Synchronizing the file on the same path of database could slow down syncronization and not synchronize your log at all in case of premature shutdown.
Also i should make a choice when doing that. This path is also used when you run Log4Om as portable, the files will be placed in the "config" folder.
It's a choice, one place or another will have different advantages. Possibility to relocate elsewhere is provided to let users that have different needs to work the way they desire without limitations :)
