Page 2 of 2
Re: Actuality of DX Spots
Posted: 04 Feb 2015, 23:52
Hi Helmut.
grouping cluster is the default behaviour of Log4OM, provided QSO are in the same BAND (QSO are not merged if they are coming from different band or modes)
There is an option to UNGROUP cluster, to act like typical clusters but this option should be deliberately set in settings.
Mouse over is simple, but will create a couple of troubles, because will be triggered also when you move your mouse over the cluster list...
Posted: 05 Feb 2015, 08:39
by oe4hds
Hi Daniele,
great. I found the checkbox for ungroup cluster. Don't know when and why I checked that. Now I unchecked it and it works as I like it. Only thing I noticed: I had to restart log2om to get it working. No big deal.
On the mouseover, you just have to check if the mouse cursor is in the range of the cluster list and then do nothing. Simplier solution would be, to do nothing on mouse over, if the cluster list is visible.
I would let the list be visible as long as you are in the list with the mouse cursor. I don't know how other hams would like it to act and there is a possibility that the version I would like it to act is not that what others want. So wether you could make it adjustable or just leave it as it is. I do not want to be the cause for troubles :oops:
73 de Helmut
