Page 2 of 8
Re: WFF list out of date
Posted: 01 Jul 2015, 09:12
IW3HMH wrote:I'm a bit confused...
i've found a WFF (world flora fauna) that seems the original one, but seems unsupported since 2012(?)
and i've found a WWFF (Worldwide flora Fauna) that seems more recent and active...
They're sharing the same reference codes?
What is the award you want to be updated?
Is the "old" WFF still operative/in use?
The old WWF ceased in 2012 and was recreated as Worldwide Flora and Fauna Award (WWFF)
So
WFF is dead
WWFF lives today and its the one we use
Posted: 01 Jul 2015, 09:37
I've found the complete and up-to-date reference here:
http://www.dcia.it/iffa/index.php/downl ... lora-fauna
preparing the update package...
Posted: 01 Jul 2015, 15:21
by VK5PL
As far as I know there is only one WWFF (World Wide Flora & Fauna Award).
What we have been asking about to be updated are the Australian Parks that are part of this Award.
Several new parks were added to the award in VK5 and VK3 earlier from about VKFF-743 to VKFF-832
The last ones I asked to be added were VKFF-833 thru to VKFF-865 which were from VK1.
The VK range should now be from VKFF-001 to VKFF-865.
Many different countries will have their own range of codes.
Posted: 07 Jul 2015, 08:02
The WWFF list is managed by 2 italian guys. I've got the updated CSV, i'll upload during lunch time today (14.00 CET)
Posted: 10 Jul 2015, 12:50
WFF is now up-to-date.
Pse update your awards and check
Posted: 11 Jul 2015, 01:38
by VK5PL
I have v1.22.0.0 but when I look at the External file information under About Log4OM, the award update date is 29/01/2015.
I thought the awards updated automatically.
Is there any way to tell if you have the latest update for the awards?
Posted: 11 Jul 2015, 05:53
by vk2io
I performed a manual update on the awards database and the following errors appeared in my log. It seems the award_WFF.xml.gz update file is not on the server as I could not access it through a browser either.
Cheers,
Gerard - VK2IO
2015-07-11 15:28:54.2508 INFO: FileManagement: -> downloading http://www.log4om.com/log4om/resources/awards/award_WFF.xml.gz ...
2015-07-11 15:28:56.8010 ERROR: *** FileManagement: award_WFF.xml ******* [Function: #=qHbaExOKbrdtYlA_FD0dEOYDFhfl_QK$S4rAAXOtD2sQ=] System.Net.WebException: The remote server returned an error: (404) Not Found.
at System.Net.WebClient.DownloadFile(Uri address, String fileName)
at LogOM.BL.FileManagement.#=qHbaExOKbrdtYlA_FD0dEOYDFhfl_QK$S4rAAXOtD2sQ=(Object #=qkK_3XWMyirr3m1ktwwcoIQ==, DoWorkEventArgs #=qvBt8fIEG5KHqJApChQJjLg==)
Posted: 11 Jul 2015, 06:41
You are correct, I just looked at the server and the file is not there, just the xml file, so Lele must have forgotten to upload it
As an interim measure you can download the xml file from my dropbox here
https://dl.dropboxusercontent.com/u/549 ... rd_WFF.xml
Then in the awards manager use file/import to import it
Posted: 12 Jul 2015, 02:01
by vk2io
Thanks for the file, Terry.
It installed fine with Award Manager.
There are three errors in the file.
ONFF-0306 and ONFF-0312 should have their DXCC set to 209 rather than 0.
There is an extraneous entry to REFERENCE which should be deleted.
I have made the corrections and uploaded the file for anyone interested:
https://www.dropbox.com/l/9lYkrrGwQewVAyC6XesPet
Cheers,
Gerard - VK2IO
Posted: 12 Jul 2015, 04:19
by vk2io
The new awards file seems to have 4 digit park references throughout. A lot of the references have had a leading zero added to the reference number as most had 3 digits previously eg. VKFF-553 became VKFF-0553.
What brought this about? Was it a request from the WWFF organisation?
The change is not backwards compatible. For example, in the Statistics and awards screen when previous contacts are listed, all existing references in the log (eg. VKFF-553) are shown in red and listed as NOT FOUND in the description.
Exporting a log with zero-prefixed WWFF reference number may also cause processing problems when submitting logs to the WWFF organisation.
Unless this was a request from the WWFF group, I think the numbers should revert to 3 digits.
Cheers,
Gerard - VK2IO
