Inconsistant mode selection from cluster spot
Re: Inconsistant mode selection from cluster spot
dk2lo wrote:Hi friends of LOG4OM,
I can confirm this behavior with my K3/P3 system as already described by Gary. I would be very interested in any solution of this item.
With help from Garry K9DJT I am investigating this issue, more news later
vetterestorer
Post by vetterestorer »
Same problem on K3. Go to settings and uncheck the box "cat will set mode when following spot". It fixed it for me.
Richard
K7SD
K7SD
Post by K7SD »
Well, that helped as long as you stay on one mode. LSB and USB switch correctly for the proper bands and the filters in the K3 stay on the SSB filters. However, you have to manually switch between modes... Before doing this, switching from 20 meters phone to 40 meters phone stayed on USB. A double click went to LSB on 40 with the CW filter.
K7SD
K5SD
Are you connecting the K3 direct or with a P3 or Win4Ksuite?
Is your region selected correctly in the options/station info tab
BTW I have removed your veterestorer account, you don't need two and its best to use your call sign as a user name so that we can provide appropriate assistance based on your location.
K7SD
Post by K7SD »
Yes using a P3 and the region is set correctly. I'll take the P3 out of line and test again.
Richard
K7SD
Yes please connect direct to the K3 using Omnirig and report your findings
K7SD
Post by K7SD »
Terry,
Thank you. I was using Hamlib. Works fine with Omnirig except for CW reverse -- which I have been reading about on the forum.
73's
Richard
K7SD
Richard
The CW reverse thing is an error in the Omnirig k3 file, just edit it with notepad
K7SD
Post by K7SD »
Terry:
Already done.
Thanks again.
Richard
K7SD
Another happy and satisfied customer :D :D :D :)
