Page 2 of 3
Re: CAT survey. Please vote.
Posted: 01 Jun 2015, 22:35
by VK7XX
IW3HMH wrote:
I've plans and a working prototype of a "log4om CAT" (some text deliberately omitted)
excellent !!!!!!!!
Posted: 12 Jun 2015, 20:33
by J85K
FYI -- Using Yaesu FT 2000 transceiver. No other rig at tested.
-- OMNIRIG -- assumed that poll associated my post comment .....
Regards,
Kumar_J85K
Posted: 12 Jun 2015, 23:21
J85K wrote:FYI -- Using Yaesu FT 2000 transceiver. No other rig at tested.
Regards,
Kumar_J85K
Er! Omnirig or Hamlib?
Posted: 15 Jun 2015, 19:04
by WQ4A
OmniRig!
Paul
WQ4A
Posted: 20 Jun 2015, 03:02
by wa6gxq
I have two rigs ic-746 non pro. and ic-707. I have the ic-746 working with omnirig. the ic-707 is not covered in omnirig. In hamlib the rig is covered, but will not work. The ic-707 Works fine with HRD. I use the ic-707 a fair amount. Is there any help with this isuue?? I don't think ham is a reliable product. please help.. thanks
Posted: 20 Jun 2015, 04:42
Did you try any of the other Omnirig selections for the 707 many of the Yaesu set ups will work with others
Posted: 06 Jul 2015, 09:26
by G1YBB
As a new user I went for Omnirig (I think it mentioned in the user manual it may be the better option) and once I tweaked the baud rate in the rig from it's default, is working lovely.
No reason to change, and I have recommended a friend use it also, after recommending Log4OM to him and him loving it too.
Omnirig on FT-897D
Posted: 06 Jul 2015, 17:47
by VE3VEE
I have a remote QTH with TS-480. I used to use Omnirig, but at one point it stopped working and after a lengthy experimenting with it I gave up and switched to Hamlib.
I don't recall what exactly it was that caused my Omnirig issue. It might have been an addition of a new hardware (at the remote site) and/or new software (at home), but yes, at one point I was no longer able to use LOG4OM with Omnirig.
I'm sure this post is not very helpful... sorry... if I do recall what my issue was, I will post details.
73 Marvin VE3VEE
Posted: 19 Jul 2015, 23:39
by wa6gxq
G4POP wrote:Did you try any of the other Omnirig selections for the 707 many of the Yaesu set ups will work with others
I tried other icom models, but no yaesu. i will try it. sorry about the late response. thanks
Posted: 20 Jul 2015, 00:16
by wa6gxq
wa6gxq wrote:G4POP wrote:Did you try any of the other Omnirig selections for the 707 many of the Yaesu set ups will work with others
Tried all Yaesu interfaces. no success.
