Page 2 of 2
Re: OMNI RIG and IC7100
Posted: 05 Jun 2015, 09:36
by G3XOV
UPDATE: Just reset everything except the CIV address which I have left at 80h and everything is working ok with Omnirig set for IC7410.
73 de Ron.
Posted: 31 Mar 2018, 13:25
by g4cfp
Hi Guys
I have my IC-7300 configured and working as Rig 1 but I'm unable to get my IC7100 to connect as Rig 2. I have followed the post and tried without success, does anyone have a list of Connector settings in the IC-7100?
Cheers
Bill G4CFP
Posted: 31 Mar 2018, 22:30
1. Make sure that you have the latest version of Omnirig its V 1.16 and download and install the latest rig .ini files because the Omnirig install does not include the latest versions
2. Make sure you installed Omnirig to 'Run as an administrator'
3. Make sure that you installed Log4OM to 'Run as an administrator'
I have an IC7600 as rig 1 and IC7100 as rig 2 working 100% OK
My settings are shown beow but your com port and baud rate is probably different
- Untitled.jpg (29.62 KiB) Viewed 3691 times
- Untitled2.jpg (29.52 KiB) Viewed 3691 times
Posted: 01 Apr 2018, 10:44
by g4cfp
Thanks for the post
I do run both as administrator and have checked my Omni Rig setting and they look ok. I will dig the 7100's manual out and see how I setup the USB Comm's port to match up with the Omni Rig setting
Regards Bill G4CFP
Posted: 01 Apr 2018, 11:24
by g4cfp
Hi from an embarrassed member
I had the wrong com port selected.
Many thanks Bill G4CFP
