Sync problems with Fldigi
Robert SP8SN
Re: Sync problems with Fldigi
Post by Robert SP8SN »
Hallo All.
I have just started using Log4OM. I changed from HRD.
I have the same problem. I made everything as in the youtube tutorial.
XLM initialize in FLDIGI, then all in LOG4OM - communicator / FLDigi setting.
All the time frequency is 0000 Fldigi, and in Log4OM communicator third green led (connection to FlDigi inbound) after a few seconds are changed to red. In the Activiti Log is unexpected error - FlDigi TX.
All programs run as administrator - Windows 7.
What could be wrong ?
Best regards, Robert SP8SN
Have you restarted Log4OM and FLDigi?
Are you sure that you don't have a firewall or antivirus blocking the software?
Have you checked the boxes for send and read frequency in the communicator/inbound/FLDigi interface?
Is Log4OM and the communicator DEFFINATELY running with administrator privileges?
Robert SP8SN
Hallo, I thing everything is correct.
Here is some screenshot movie: https://www.dropbox.com/s/95u7ampuz78ss ... 7.avi?dl=0
Here is solution: I uninstalled the latest version 3.23.13 and installed older 3.23.08. Everything worked properly.
I dont know what is the new version problem. I checked all the settings are the same.
Robert SP8SN
OK now in newest ver. Have to create in and out rule in windows firewall, allow all connections by fldigi.
Seems FLDigi may have changed something!
