SOTA
Re: SOTA
W6JMP wrote:Then I must have restarted the cluster. Is it possible that this is memory problem?
I read this thread when it was first posted and set my cluster to the SOTA cluster on 13th November, my computer has been running all the time until now without restart and the cluster has not stopped working
I think you have a local issue of either internet interruption, memory issue or something similar
Re: SOTA
Since no one else seems to have the problem, I think it may be time to write the issue off as a local anomaly. Log4Om is a great program and the SOTA cluster is tracking (syncing) correctly 90% of the time. I can (and do) track SotaWatch2, so not much chance of missing a spot. Having to manually enter a SOTA Q occasionally is no big deal.
Thanks for looking at my problem and thanks again for a TERRIFIC PROGRAM.
73 de gene w6jmp
73 de gene w6jmp
Re: SOTA
All other clusters watched tracked perfectly on f9
BUT THIS COULD BE A BREAK THROUGH. This morning any post or spot marked SMS_NA did not sync to F9 from the SOTA cluster. I will watch further to see if there are any other spots that don't sync.
