They will be available on next release.
Country will remain, we have stripped the string "country:"
Remove "To:" from address print label?
Re: Remove "To:" from address print label?
Now that version 1.25 was released I tryied the label printing out only to find out that the TO was removed, but the space that it took up is sitll there, so I can not increase the font size of the label without flowing over the bottom margin while I have a big White space at the top.
Is there a way to fix this and have the actual printing starting more twoards the top of the label allowing a larger font?
Thanks! 73
PU2TLU
Thanks! 73
PU2TLU
it's an hard deal to keep all informations on the label, even when the callsign is big (very long).
There is not a "final solution" to do that, because K7PT uses less space than EA3/IW3HMH/QRP and labels should be responsive and correct in all those situations.
It's matter of font size, you should play with the font size until you have a good shaped PDF, then print and confirm
Thanks for your reply, but the issue is with the address label, not the QSO record label. You had a "TO:" at the top of the address label in previous versions and that was removed to gain some space. The problem is that a blank row/space is inserted there instead of the "TO:", so nothing has changed from the space point of view. If you remove that blank line, then I could use a larger font on the label and make it easier for the post office to read the label and guarantee the correct delivery.
Thanks again and I love your product, it has made my live sooo much easier! Keep it up.
Gui, 73 PU2TLU
Gui, 73 PU2TLU
