Sorry Its VK1TXK7PT wrote:Hi Tex,
We would greatly appreciate to know your call sign. Please!
OMNIRIG and IC 7300 HELP
Re: OMNIRIG and IC 7300 HELP
I think you Hit the nail on the head!
That's what I did eh!
I will try to uninstall all the Icom drivers and also reinstall OMNIRIG and see what happens.
Also just a point still cannot see IC-7300 on the cat listing in the Log4OM software.
regards,
TEX
ps thanks for the nice videos on Utube.
regards,
TEX
TexTEX wrote:Hi Terry,
regards,
TEX
Make sure that you uninstall Omnirig to ensure that the latest ini files are installed with the new version of Omnirig - Don't use an existing download of Omnirig, download a new version
OMNIRIG and IC 7300 Help
Hi Terry
Got all working nicely but still getting used to new program also got it to work with WSJT and JT alert 90% of my work.
Have the 7300 file for omnirig but it is far from stable when on WSJT the QRG and or mode jumps and CAT is lost need reset WSJT, a bit annoying when in middile of QSO
Could not find Omniri forum any pointer would be welcomed
73 Jacques
73 Jacques
Icom 7300- Dipoles
BY-1 Bencher - KT-1 keys
PCIntel i3 3.3GHZ - 16GB Ram - 1To external backup - QL700
PC: Win 10 Pro X64 - MS Office. Avast. NTP 4.2.8
Log4OM - N1MM - MTTY - WSJT-X 1.6.0 - JTAlert 2.8.4
Memberships: REF - ARRL.
Upon further investigation- observation I noted the following:
If doing QSO while doing changes to Log4OM TX was erratic if left the set up run and made no changes to Log4OM the it was stable ...
strange behaviour ?
strange behaviour ?
Icom 7300- Dipoles
RF in the shack maybe?
I was just working some stations and was logging at the same time without issue so it's not the software!
Hi Terry
No RF in shack this morning stable until I went to 20M from 40M erractic and even when reverted back to 40M on JT65
out of interest went back to HRD RIg Control can move all bands an stable . wonder if Rig control HRD can work with your software
anyway have a good week end Jacques
Icom 7300- Dipoles
No and it never will Jacques!
Same Radio, cable and computer with HRD?
I thought as much anyway set up is absolutely all identical in all aspects
Just have to change the WSJT radio settings from Omnirig Rig 1 to HRD that is all that is changed power out 20W same etc etc .
BTW no RF in shack .
So currently using Rig control Jt alert logging to Log4OM works fine if not ideal .
Icom 7300- Dipoles
