EQSL - Resolved
Re: EQSL
ei9ju wrote:I'm still having an issue with EQSL upload, like Mike KA4CDN, I've doubled checked username and password info but still can't get it to work through Log4om, using the same username and password I can upload using the EQSL site.
Gerry/Ei9Ju
Has your user name or password got any special characters in it like _ / & * | . + ?
ei9ju
Re: EQSL
Post by ei9ju »
No Terry.
Re: EQSL
it's your QTH Nickname set?
In my account is called "Home", because Log4OM supports multiple profiles and multiple profiles are supported on eqsl too, you must provide this parameter
In EQSL:
In Log4OM:
Re: EQSL
ei9ju wrote:No Terry.
Then you must be using the wrong Nickname
ei9ju
Re: EQSL
Post by ei9ju »
That must be it even though my own EQSL account has that field left empty. I'll re-config Log4om setting "Home" as the nickname and let you know later if it works.
Edit; to the best of my knowledge Terry the nickname field was never filled in during EQSL registration, it's really only something needed for uploading from a second location/computer and that's something I never intended doing, correct me if I'm wrong but filling in the nickname field was optional and not a requirement for EQSL registration.
Re: EQSL
ei9ju wrote:to the best of my knowledge Terry the nickname field was never filled in during EQSL registration, it's really only something needed for uploading from a second location/computer and that's something I never intended doing, correct me if I'm wrong but filling in the nickname field was optional and not a requirement for EQSL registration.
FYI if you don't complete the eQSL nickname field when registering with eQSL it defaults to 'Home"
It would be best for you to go and look at eQSL and check what it is!
ei9ju
Re: EQSL
Post by ei9ju »
Yes, the "nickname" field must be set to "home" for Log4om upload to work, I've just done a sample QSO after re-configuring my Log4om external log using "home" and it automatically uploaded.
I've looked at my EQSL profile again and see there is indeed a name in the Nickname field and it's the same as the username I registered, strangely enough it's not "home" and that's the one I've used in Log4om and it worked, i then tried the EQSL nackname and that one worked too.
I'm almost certain I left that field empty when I registered with EQSL, mind you it was years ago, I wonder if it's not set does it automatically revert to the Username?.....just incase anyone else finds themselves in the same quandry. ;)
edit; I was typing as you were posting Terry so your last answer more or less answered it.
Re: EQSL - Resolved
I will set this by default, or i will place a small hint on that.
Log4OM is "multi configuration ready", so this field is needed to upload to Eqsl using their "multi configuration" functions.
This is the "what is this" in EQSL website:
so it's necessary to have it set. Other software probably defaults with nickname but they cannot, in this case, upload QSL to different accounts.
thank you for reporting that, we now can take some actions to make it clearer :)
KA4CDN
Re: EQSL - Resolved
Post by KA4CDN »
Can anyone confirm one way or the other whether or not Log4OM External logs to eQSL or not? I've got the EQSL Setting set on the "External logs" Settings dialog tab yet my contacts are not getting uploaded. I am not a paid eQSL user and I wonder if that is my problem? Please let me know if I need to be a paid eQSL member so I can stop beating my head against the keyboard here!
Thanks,
Mike
Re: EQSL - Resolved
There is no difference (in QSLíng) between "payed" users or "free" users. Only for eQSL award collectors it´s a difference you have AG or not (AG is free too). If you make some donations and climbing up to bronce, silver or gold membership you only have some more "features" at the eQSL website (e.g. loading up a personal picture for your card and some more). Have nothing to do with up- or download of eQSL verifications.
Think there will be another problem (Password, QTH-Settings e.g.)
