Robert,
Keep in mind, the bandplan has no bearing on how the spot is sent. Your spot was sent as SSB, no worries there. The bandplan comes into play in how the Cluster display sets the Mode field for a particular spot.
Doug - W7DRM
Mode reported to DX Cluster incorrect
Re: Mode reported to DX Cluster incorrect
I appreciate your explanation, but I'm still no closer to solving this. If I send a "spot" on or near that frequency, while operating SSB, it shows up on the cluster as DIGITAL. LOG4OM's log file shows it correctly as a phone contact using SSB. Just trying to figure out what needs to be changed so that the spots get sent correctly. I've also tried another cluster with the same results.
Hopefully this will get fixed in V2.0
Robert,
In your example, the spot is NOT being sent as DIGITAL. Your spot is being sent by frequency only. What you are seeing in the Cluster display MODE field is Log4OM's interpretation of the MODE, based on the bandplan files. Its only an interpretation, not what you sent.
Doug - W7DRM
Doug - W7DRM
Right.
Band plan is applied on received spot (that doesn't contain mode informations). Log4OM uses the USER bandplan to identify the region.
Sometime can happens that a spot that appears as DIGITAL is in the PHONE bandplan area in another IARU region (the spotted callsign region).
In that case the spot is reported according to YOUR bandplan. That means if you answer to this call (that is actually an SSB call), you are using voice in a DIGITAL bandplan region for your location.
Doug,W7DRM wrote: 05 Mar 2017, 00:19 Hi Robert,
Your bandplan file determines which mode is displayed in the Mode field of your Cluster display.
To solve this, go to your configuration folder (Help/Open Configuration Folder), and find the bandplan291.xml file. (see last paragraph, below, if you do not have this file). Open that file with Notepad. Scroll down to the section on 40m. If yours is like mine, the BandPlanRange for 7035 to 7150 is designated as "Digital". Your spot of 7,137 is in this range. Basically the Mode field in the Cluster display uses this plan to determine mode, not the mode sent in the spot report. So your spot was correct, just the interruption of the spot in your Log4OM cluster was off, due to the band plan.
If you want to alter this band plan, you can copy this file to a file called bandplan291_user.xml, then modify the plan to make the Digital section smaller or as you wish. That way, your bandplan291_user.xml file will be preserved after a program update where there may be a new bandplan291.xml file furnished.
I should also mention that there is a hierarchy of bandplan files. If you do not have a bandplan291.xml file (291 DXCC entity), then the bandplan_r2.xml file is used. (Region 2). So you can create a bandplan_r2_user.xml file if you do not have a bandplan291.xml file.
Doug - W7DRM
Finally decided to try and fix this.
1. The file you mentioned, bandplan_291.xml di not exist. I do have bandplan_dxcc291.xml.
2. Perhaps I made a bad decision, but I edited the digital portion of that file, to change 7150 down to 7125.
3. Now, as soon as I go below 7150, LOG4OM shows OUT OF BAND, regardless of what mode I'm in.
4. I suppose I can just install LOG4OM on another PC and copy that XML file over the one I modified.
5 I also have the bandplan_r1 (through) _r3. Not sure about hos these are used, and why _r2 would be used before _R1.
I've included the 40m portion of bandplan_dxcc291 below. I'm really sorry to reintroduce this issue ... I guess this is one of the artifacts of getting old!
<BandPlanRange>
<Band>40m</Band>
<Start>7000</Start>
<End>7035</End>
<BandUpperLimit>false</BandUpperLimit>
<EmissionType>CW</EmissionType>
</BandPlanRange>
<BandPlanRange>
<Band>40m</Band>
<Start>7035</Start>
<End>7125</End>
<EmissionType>DIGITAL</EmissionType>
</BandPlanRange>
<BandPlanRange>
<Band>40m</Band>
<Start>7150</Start>
<End>7300</End>
<BandUpperLimit>true</BandUpperLimit>
<EmissionType>PHONE</EmissionType>
<ModulationType>LSB</ModulationType>
</BandPlanRange>
<BandPlanRange>
I got the out of band issue corrected.
So here is the 40m portion of Bandplan_r2.xml
7035-to 7125 is already designated for "digital" if I am understanding this correctly. Yet, any spot on the cluster (SSB) only shows up as "digital" in LOG4OM.
I apologize for not understanding this - hopefully someone can set me straight.
<BandPlanRange>
<Band>40m</Band>
<Start>7000</Start>
<End>7035</End>
</BandPlanRange>
<BandPlanRange>
<Band>40m</Band>
<Start>7035</Start>
<End>7125</End>
</BandPlanRange>
<BandPlanRange>
<Band>40m</Band>
<Start>7125</Start>
<End>7300</End>
</BandPlanRange>
<BandPlanRange>
<Band>40m</Band>
<Start>7000</Start>
<End>7035</End>
</BandPlanRange>
<BandPlanRange>
<Band>40m</Band>
<Start>7035</Start>
<End>7125</End>
</BandPlanRange>
<BandPlanRange>
<Band>40m</Band>
<Start>7125</Start>
<End>7300</End>
</BandPlanRange>
Hi Robert,WA2SQQ wrote: 30 Jul 2017, 02:44 I got the out of band issue corrected.
Correct. These bandplan files only effect what mode the spot is believed to be, according to the band plan - only affecting the Mode column in the Log4OM cluster display.
One other point. Log4OM uses the bandplan-r2.xml file if it does not find a bandplan_dxccXXX.xml file - (XXX) being the DXCC number of your QTH, in our case - 291. Plus, if Log4OM finds a bandplan_dxccXXX_user.xml file, it will use that over the generic bandplan_dxccXXX.xml file.
So the hierarchy of bandplan files are from lowest priority to highest:
bandplan_rX.xml - your region - in our case, IARU region 2
bandplan_rX_user.xml - your region file customized
bandplan_dxccXXX.xml - your dxcc country - in our case - 291
bandplan_dxccXXX_user.xml - your dxcc country customized for you.
The ...._user.xml file are used so that your changes are not overriden by a Log4OM program update which might include a newer version of the region or dxcc bandplan files.
So, in order to preserve the changes which you have made, and make them effective, you need to modify a copy of the Bandplan_dxcc291.xml file - which is for the U.S. specifically. So make a copy of the bandplan_dxcc291.xml file, then rename that copied file to bandplan_dxcc291_user.xml. Then in that new file, make the same changes to the 40 meter segment which you have outlined above. Then you should be set, and won't lose those changes the next time you upgrade Log4OM.
Doug - W7DRM
I see this is a old thread but I to am having the same problem. I asked this question in a recent forum but stumbled upon this trying to fix the problem. I believe my settings are correct as I am in region 1 I think. Anything below 7.150 shows as digital and when I use my CAT control to click and go to that freq the radio goes into USB. I guess all of this time I have been saving theses qso as digital? How can this be corrected? Thanks.WA2SQQ wrote: 04 Mar 2017, 14:01 Worked a station on 40M SSB, on 7.137
The contact was logged as SSB, but the spot to the DX cluster was designated as DIGITAL.
Mike-W2MJP
Mike-W2MJP
Well according to your call sign your in region 2?
Think so too. IARU R1 is Europe and parts of Africa. There´s a nice WIKI to find
out what is in which region:
https://en.wikipedia.org/wiki/Internati ... adio_Union
