CAT connection to yaesu FT 747GX
Re: CAT connection to yaesu FT 747GX
Sorry,
I forgot:
Stop bit: 1
I forgot:
Stop bit: 1
Follow the instruction to generate a support request as detailed here:http://www.log4om.com/log4om-support/ and email it to me at g4pop (AT) arrl.net
When you generate the request please check the include ADIF box
DO NOT PLACE THIS ON THE FORUM - EMAIL IT TO ME AS DIRECTED ABOVE
Hello Terry,
It's done backup and zip file are sent to your email.
Best regards
Patrice
Best regards
Patrice
Hi Patrice,
you wrote "FT-747GX". Are that the first GX or GX1, GX2 ? And if it is GX have you set the correct radio ?
In the RIGS folder of Omnirig are 4 different FT-747 ini files. So it could be possible you have klicked a
wrong one.
Only an idea
wrong one.
Only an idea
Hallo Jürgen,
Vielen Dank für deine Nachricht. Ich glaube, ich habe alle 3 Einstellungen ausprobiert aber die verschiedenen Konfigurationen für die 3 Transceiver sind die gleichen ( Baud Rate, Stop , parity bits usw...). Ich weiss auch nicht welche Version ich besitze.ch will es nochmal probieren.
Besten Grüsse
Patrice
Hello Jürgen,
Thanks for your idea. I believe, I did test all three versions of the FT 747 GX but the settings are the same for all of them. I don't know which version I use. But I will try again.
73 de Patrice
Besten Grüsse
Patrice
Hello Jürgen,
73 de Patrice
Hallo Patrice,
wie gesagt, war nur so eine Idee. Mal sehen was Terry herausfindet.
As i said, only an idea. Let´s see what Terry is finding out
Could I ask if this ever got sorted out as I am having the same issue with my FT747??
DE 2E0DYP
DE 2E0DYP
These are the Omnirig settings to use plus of course your com port and baud rate to match that of your radio
Thanks Terry I will have a go.
