Cluster (F9) Note & Other Info Columns
Re: Cluster (F9) Note & Other Info Columns
* indicates that this is a LOTW user
NN7D
Post by NN7D »
Nolan,
In the Cluster window or Cluster tab (F9) a skimmer spot will have notes in the form "CW 13 db 15 WPM..." for cw, and "RTTY 13 db CQ..." for RTTY. That is the only way I know of to tell whether the spot is from a skimmer or a normal human type spot in Log4OM.
As you indicated in the DX tab of CC User, skimmer spots are noted with a # sign.
Doug - W7DRM
