Here are 3 files to put in C: \ Users \ xxxxxxxx \ AppData \ Roaming \ LogOM
Add mode JT10 FT8
73 ON3LA
New Mode - FT8
Re: New Mode - FT8
RSTMode.csv
- (64 Bytes) Downloaded 310 times
reportlistJT.txt
- (761 Bytes) Downloaded 353 times
modelist.csv
- (2.2 KiB) Downloaded 342 times
Re: New Mode - FT8
Ok Terry I'll try that. I guess because it's new and kind of neat. I am aware of that it's less sensitive. My favorite is still JT9, then JT65 and after that I like a little voice SSB once in a while.
Dan Malcolm
K4SHQ
K4SHQ
Re: New Mode - FT8
Try the files from ON3LA firstdmalcolm wrote: 04 Jul 2017, 07:39 Ok Terry I'll try that. I guess because it's new and kind of neat. I am aware of that it's less sensitive. My favorite is still JT9, then JT65 and after that I like a little voice SSB once in a while.
Re: New Mode - FT8
I'll try those files. Quick question. eQSL provides an ADI file for download, and then Log4OM processes that ADI file I believe. Is it possible for me to see the unprocessed file?
Dan Malcolm
K4SHQ
K4SHQ
Re: New Mode - FT8
Those files made no difference that see. At least not yet. I did download the eQSL inbox as an ADIF. That record looks clean.
Dan Malcolm
K4SHQ
K4SHQ
Re: New Mode - FT8
I created a single record ADIF from the downloaded eQSL inbox ADIF and imported that. It imported fine except that in place of JT65 was FT8. No idea why but I'm just reporting.
Dan Malcolm
K4SHQ
K4SHQ
Re: New Mode - FT8
Don't forget that the modelist.csv file should be saved as modelist_user.csv because Log4OM will be loading the user file now that you already modified it, not the default modelist filedmalcolm wrote: 04 Jul 2017, 08:20 Those files made no difference that see. At least not yet. I did download the eQSL inbox as an ADIF. That record looks clean.
Re: New Mode - FT8
Actually I didn't know that. But I kept a copy of the original modelist.csv file so I could have a fallback (years of screwing things up and needing a fallback). Thanks Terry.
Dan Malcolm
K4SHQ
K4SHQ
