Page 2 of 4
Re: ic-7300 CAT problem- delay
Posted: 25 Sep 2017, 15:43
sq7bcn wrote: 25 Sep 2017, 14:47 Ok please email address ...
I already said g4pop (AT) arrl.net
(AT) is @ I don't write the email like [email protected] to stop spam
Posted: 25 Sep 2017, 17:10
by sq7bcn
VA3AG wrote: 25 Sep 2017, 15:16
sq7bcn wrote: 25 Sep 2017, 05:47 I'm using Omnirig, changing to administrator rights has not improved.
The bitrate is 19,200 because only the trx connection is set up just as the rest of the settings(bitstop etc) are correct as in other programs Loger32, JTDX, WSJTX- work properly.
You need to set your radio to 115.200 baud rate.
No in IC-7300 is only 4800,9600,19200,Auto I set 19200.
Posted: 25 Sep 2017, 19:40
by sq7bcn
I think the problem is in Rigs file Icom 7300.ini
Loger 32 have the same setings com, baudrate , stop bits ,polling int.=1000ms etc.)and work fine.
Posted: 25 Sep 2017, 21:46
by VA3AG
sq7bcn wrote: 25 Sep 2017, 19:40 I think the problem is in Rigs file Icom 7300.ini
I have mine set for 115.200 baud rate and it connects just fine, at 19.200 baud rate mine did not work.
Good luck!
Posted: 26 Sep 2017, 06:17
by sq7bcn
Ok
You have set:
CI-V USB Port - UNLINK from Remote
CI-V USB Baud Rate - 115200
CI-V Baud Rate - 19200 it probably doesnt matter ...
Posted: 26 Sep 2017, 16:26
We have many users that have the 7300 working fine with the 7300.ini so it has to be something local on your computer set up.
I still have not received the Support request with 'Trace' mode activated ??????????????????????????????
Posted: 26 Sep 2017, 16:57
by sq7bcn
Ok Terry I send correct support file.
Today I have change baudrate for 115200 CAT not working (Red Lamp) 38400 the same problem .
19200 work - very unstable -not for work.
I checked WSJT-X program for 115200 work fine.
Maybe the 7300.ini file I got some bad or old because therewas no file in the instalation file to 7300.
Posted: 02 Oct 2017, 06:51
by sq7bcn
Problem has been solved.
I removed the driver from the computer, restarted my computer and reinstalled the same driver - it helped.
I did not do this before because the rest of the programs worked properly - that made me wrong.
Posted: 02 Oct 2017, 08:47
Sounds like my email suggestion to you
Did you install the genuine ICOM USB driver before connecting the radio? The Windows driver will not work properly with the ICOM 7300
The USB driver has been an issue with all of the latest series of Icom radios especially if you connect the radio and then try to install the Icom driver or worse still let Windows install the driver automatically
Posted: 02 Oct 2017, 10:11
by sq7bcn
The driver was installed correctly and did not show problems with 3 other programs so I assumed the problem was elsewhere.
Your suggestion Terry helped me with this topic - Thank You.
