https://www.dropbox.com/s/kjd37vcswcqjc ... 2.JPG?dl=0
As can be seen in the image, I have adjusted my Windows clock to UTC, 24-hour format. Are there any other settings I should be looking into?
Thanks.
Local vs UTC printing on labels
Re: Local vs UTC printing on labels
A search of the forum finds your answer4F3BZ wrote: 24 Jun 2019, 22:54 https://www.dropbox.com/s/kjd37vcswcqjc ... 2.JPG?dl=0
Thanks.
See viewtopic.php?f=6&t=3722&p=20947&hilit=12+hour#p21019
You have something set wrong in the Windows Time date options
I figured it out. My Windows time/date settings are fine. The problem is with the pdf printer I was using (which was Microsoft print to pdf). After I changed to simply Save as pdf, the AM/PM thing disappeared. The labels I created are now showing the time as it is formatted in the log.G4POP wrote: 25 Jun 2019, 07:59
Thanks and 73
Boyet 4F3BZ
I am having the same issue here...the date is being printed as the correct UTC time as pulled from the log, but it is printing it in 12 hour format. I fail to see how a Windows display setting can cause this. Something appears to be telling Log4OM to use 12 hour format.
Log4om uses whatever Windows date and time format is set in WindowsW4ATX wrote: 13 Aug 2019, 22:17 I am having the same issue here...the date is being printed as the correct UTC time as pulled from the log, but it is printing it in 12 hour format. I fail to see how a Windows display setting can cause this. Something appears to be telling Log4OM to use 12 hour format.
Log4om does not dictate the format used
