Kenwood ts590sg + omni-rig
SQ5TDZ
Re: Kenwood ts590sg + omni-rig
Post by SQ5TDZ »
DF5WW wrote: 16 Jan 2019, 13:49 Hi Andrew,
there is no difference between the portable and installed version of Log4OM.
The reason is only that you have to declare Windows the "Run as Administrator"
if you use the portable one.
You tell us now that there is a delay between FlDigi and Log4OM. Did you read
the manual how to use RigCTRL connection and have you realised that FLDigi
have to start first after installation, setting it up (restart of both needed) and
connecting to Log4OM ??. Having here some transceivers and FLdigi with Log4OM
running fine.
I do not know what was wrong, but after installing the normal version everything is ok. I always run the program as an administrator!(I read the instructions). Between log4om and fldigi there is a delay of about 2 seconds, I do not know why.the fldigi itself works ok but in conjunction with log4om through XML-RPC there is a delay of about 2 seconds
Andrew.....SQ5TDZ
In Fldigi is there any other CAT control active
Did you know that you must also run Fldigi and any other software that communicates with Omnirig and log4om as administrator also?
SQ5TDZ
Post by SQ5TDZ »
G4POP wrote: 16 Jan 2019, 15:15 In Fldigi is there any other CAT control active
yes I know that fldigi need to run as an admininstrator and I do it, everything works only this delay is when I turn on broadcasting. there is nothing to deal with this problem, the most important thing is that it works
Thank you for your help
greetings
Andrew.....SQ5TDZ
