Page 2 of 5
Re: V2 - no spot in Cluster (F8)
Posted: 20 Jan 2020, 00:21
by NN7D
N9BBE wrote: 19 Jan 2020, 22:28 Also noticed the 'File/Exit' does not work, nothing happens when clicked. I have to click the red X in the upper right
corner to close the Cluster Management window.
Jeff - N9BBE
Thanks Jeff. I can replicate that. We will get this fixed in next release. Thanks!
Doug
W7DRM
Posted: 20 Jan 2020, 08:22
by vk1hx
This seems to be a hit and miss issue of not showing cluster information on the cluster tab. It connects to a server and show cluster info but does not replicate to the right spots. Very frustrating. No filters selected etc.
EDIT: I've got the cluster working again. I just reinstalled the application over the top again. Something got screwed up somewhere..
Cheers and 73 all.
Posted: 20 Jan 2020, 19:36
by N9BBE
Re-installing did not fix this for me. Still no spots showing on the map or the cluster screens (F8). I am connected to 2 clusters, I see I get logged in and spots get downloaded. I did notice if I open the band map using the icon at the top of the main UI spots show there. Strange....
Any suggestions???? I'm at a lose with this one.
Jeff - N9BBE
Posted: 20 Jan 2020, 20:20
by NN7D
Jeff,
Do you have TeamViewer installed on your shack computer? If you do, let me know and I can assist you remotely.
Doug
W7DRM
Posted: 20 Jan 2020, 20:25
by N9BBE
Doug, if you have time now I'll get teamveiwer installed. Give me a couple minutes.
Jeff - N9BBE
Posted: 20 Jan 2020, 20:34
by N9BBE
Done, sent you a PM.
Jeff - N9BBE
Posted: 20 Jan 2020, 20:57
by IK0TIX
Jeff to really reinstall everything you must also delete the log4om folder in C:\Users\maxip\AppData\Roaming\Log4OM2 otherwise you will not delete the configuration data
Posted: 21 Jan 2020, 18:55
by N9BBE
Max, thanks for that reminder. After a couple hours with Doug on the phone and temviewer, no joy. Still no spots showing in any of the cluster windows (except for the Cluster Manager where it shows the login info). After I hung with Doug (thanks again Doug for all your time) I was away from the computer for a few hours doing other things. When I came back there was spots populating the cluster windows (F8 tab and the external cluster window). What happened when I was away from the computer I have no idea. Feeling frisky I closed and opened Log4 a few times and all cluster functionality continued to work. Software healing itself.... :twisted:
I'll be running Log4 V2 as much as can over the next week to see if this issue surfaces again.
Jeff - N9BBE
Posted: 23 Jan 2020, 11:07
by IK0TIX
Jeff, it actually seems like a sporadic problem (it reminds me so much of my RF problems that appear and then disappear on their own).
I'm putting the cluster under stress: column reconfiguration, filter insertion ... etc. I hope to catch the bug again
Posted: 25 Jan 2020, 13:36
by IK0TIX
it happened again.
After 10 minutes everything went well
